Old 11-24-2007, 02:10 PM
gasman gasman is offline
Default IS IT OK TO USE BRASS??
I had to remove the oil pressure fitting by the right top motor mount. It was not tight enough. Took a hack saw and cut it in half to remove due to the lack of space.
Now the only way is to use a 1/8" 45 st el and then a -4 to 1/8 npt. It is ss... but the st el is brass!! I can't find a steel one. What do you think..
Old 11-24-2007, 04:02 PM
Harvey L. Sorensen Harvey L. Sorensen is offline
was the fitting that you removed by any chance a restricter fitting? You may have to buy one from Lycoming.
Old 11-24-2007, 09:35 PM
Yes,it was restricted. But I can duplicate that in the brass st el........
Old 11-24-2007, 11:17 PM
Mark Burns's Avatar
Mark Burns Mark Burns is offline
Default I think so
Gasman,
I think brass is fine for this application.
If you want to find some really neat fittings just find the nearest industrial hydraulic shop that sells Parker fittings.
I was using some fiittings at work the other day that were 1/8" brass elbows with one side male and the other female. Basically a street ell but in a super small package. Wish I had a photo of one, maybe I can post one later.
Mark
Mark Burns
Ruston, Louisiana
RV-7A N781CM 1,650+ hrs
FFI FL-24
A&P
