Old 11-21-2007, 04:02 PM
tomhanaway tomhanaway is offline
Default aileron/pushrod- fitting threaded rod ends
Rv-10 page 23-3 calls for inserting the an490-ht8p threaded rod end into each of the four ends of the bellcrank/aileron pushrod. Even with lube (and prior to the added thickness of priming), the rod ends aren't inserting into the tubes unless I take a mallet to them.
Did anyone else find they had to grind down the cylindrical part (or the inside of the pushod) of the threaded rod to get it to fit inside? Hoping to avoid this but I'm not seeing any other way.
thanks,
Tom H.
Old 11-21-2007, 04:16 PM
jlfernan's Avatar
jlfernan jlfernan is offline
You may have some burrs inside the steel tube. Sand the inside LIGHTLY with a Dremel tool and you should be OK.
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 11-21-2007, 05:49 PM
GAHco's Avatar
GAHco GAHco is offline
Default What I did.
Mine had to be cleaned inside because the ends were slightly burred and irregular after being cut.
I uses a fine round file about 1/4 of 5/16 in diameter and just ran it back and forth to clean the inside area.
They are supposed to be a snug fit, but you should not have to remove any of the rod end. I did need to help them go in with some light tapping, I set the threaded in the right size long socket to protect the threads and then tapped on the tubing with a piece of hardwood between the hammer and the tubing.
For a lot of info on this application see
http://www.vansairforce.com/communit...ead.php?t=8358
or search "Aileron Pushrod"
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 11-21-2007, 08:28 PM
Jeff R's Avatar
Jeff R Jeff R is offline
Mine took some gentle persuasion. Be sure to deburr the ends of the tube first.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
