Old 11-21-2007, 10:38 AM
cjensen's Avatar
cjensen cjensen is offline
Default Do I need a Facet pump?
I just ordered my finish kit, and did finally choose an engine...O-320.
I was working on fuel line routing last night, and noticed on the plans this little Facet fuel pump...
It says "if required; not provided with kit". How do I know if I need one?
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 11-21-2007, 10:43 AM
asu4me asu4me is offline
Default pump
Chad,
The Facet pump that mounts in this location is for engines with a carb.
Jerry Kosirog
Mesa, AZ
RV-7A Flying Phase 1
N855GK
rv74me@yahoo.com
Old 11-21-2007, 11:02 AM
cjensen's Avatar
Quick response, quick order! Just called Van's to get one on the way!
Chad Jensen
Old 11-21-2007, 11:03 AM
sprucemoose's Avatar
sprucemoose sprucemoose is offline
I believe it's included in the FWF kit if you go that route.
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
Old 11-21-2007, 11:22 AM
cytoxin's Avatar
cytoxin cytoxin is offline
Default lift/boost
this is a lift/boost pump, mounted as low as possible to push fuel to the mechanical pump. its a low wing thing. fi have that squirrel nest just fwd of the selector. you may want to get the 90 fitting as bending the last 90 before the pump has proven difficult for some.http://www.aircraftspruce.com/pdf/20...l/Cat08258.pdf i did it without it but i have one in the drawer.
pn 04 05800 a whopping 4.95
William Weesner/ still kicking.
Old 11-21-2007, 11:49 AM
N941WR's Avatar
N941WR N941WR is offline
Good advice, buy the fitting!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-21-2007, 01:11 PM
uk_figs's Avatar
uk_figs uk_figs is offline
Default buy banjo fittings also
I agree an getting the fitting, also if you have not yet piped up the fuel selector valve I would also suggest you consider banjo fitting to the valve and bulkhead fittings for the lines that go from the valve to the tanks. Matt Burch's blog has good pictures of this.
If you decide to to go the builder route get an extra 20ft of the aluminum fuel pipe as you will make many pieces before you get it right (see my pictures for the stuff I threw away)
Another thing to consider is if you go for the Andair gascolator rather than the Van's it does not connect to the fuel pump per the plans and requires different fittings and a new bracket.
Dave (Figs) (RV-7 N256F, Flying)
Dave's RV-7 Blog
Email me
