Originally Posted by jsharkey
How do you know which way up to mount the breaker switches supplied by Van's such that "down" is "off" per US convention? Jim Sharkey RV6 - Getting there!
Just get out your ohm meter or continuity tester and check. If you get continuity or low resistance (like a few ohms), that is the ON position. Put a little dot on the case as a reminder. I assume there's a KEY way in the threaded mount? Once you figure out which way is on they should all be the same.
The next question you might ask, does it matter what wire goes on what terminal of the CB/switch? Usually no, but sometimes CB's are marked with load & source, source being battery/buss. It will work either way; there is no polarity for a fuse or CB usually, but follow the manufactures instructions.
On larger planes with overhead toggles it gets more confusing. On older Boeing aircraft Fwd is ON and I believe Douglas is opposite. New Boeing overheads are mostly push button and rotary dial switches.
