Old 11-19-2007, 04:51 PM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
Default Precision Airmotive Carburetor line sold?
This just in from the AVweb;
"Precision Airmotive has reached a tentative deal with ?a group including Tim Henderson, President of Aero Accessories, and others involved in the manufacture of the Tempest brand of general aviation products,? to buy Precision?s line of MSA aircraft carburetors, according to a news release from Aero Accessories/Tempest issued Monday. The group says it plans to move the manufacturing facilities for the carbs to a facility in an undisclosed location in North Carolina. Precision announced earlier this month that it was suspending manufacture and distribution of the carbs and parts after it was unable to obtain product liability insurance. There?s no mention of the insurance issue in the Henderson Group?s release."
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
Old 11-19-2007, 04:54 PM
cjensen's Avatar
cjensen cjensen is offline
Great! It's always just a matter of time before someone picks up where someone else left off. Carbs'll be around for a long time...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 11-19-2007, 06:30 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default The Cost?
If Precision had insurance issues, I would expect the new players would have them as well. If the insurance goes up, the price of the Carburators and the replacement parts will increase.
I saw this back in the 1980's when the float kit was only $25. Then a few months later it jumped to $50 (that's when I bought my kit). A few months later it jumped to $75.
Hold on for another wild price ride..........
Paul
Old 11-19-2007, 09:38 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Lycoming fall out - new SB
Sounds like a Lycoming CYA attempt...
Not applicable to our Experimentals, of course, but a check for loose carb. screws probably would be prudent...
From an e-mail I got....
Lycoming has released a new Mandatory Service Bulletin with a 100 hour repetitive inspection. The screws that hold the bowl to the carburetor body are to be re-torqued at intervals on all float carburetors.
http://www.lycoming.textron.com/supp...dfs/SB366A.pdf
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-19-2007, 10:24 PM
N908RV's Avatar
N908RV N908RV is offline
Default I've seen it...
Gil, I know we just took this OT a bit, but this is a notable issue and glad you posted it.
Strangely enough, I saw this happen, and coincidentally on an RV at that. A friend's buddy had visited our airport two years ago as I was building my -8. They went for a ride in his -6 and noticed that it was running very rough shortly after take off, so they came back and landed immediately. The -6 guy wasn't the builder and didn't have any experience, so they asked if I'd take a look.
We took the lower cowl off and I poked and prodded around the carb - my first instincts were that it was a mixture issue of some sort. I inadvertently bumped my hand on the FAB and it MOVED! "Holy carp Batman!" As it was getting dark out and my friend was holding the flashlight at the back of the carb I was able to see light coming through the gasket between the carb body and the float bowl. Sheesh, no wonder....
The screws had started backing out. I gave them new star washers and loctite and buttoned everything up. Ran perfectly after that. But, I emplored them to consider drilling and saftey-wire the screws together. I thought it was a bad design not to have safety wire considering how much vibration the carb sees. After all, they safety wire the heck out of their fuel injection servos.
Anyway, some good FYI fodder for the archives. Carb owners, do yourself a favor at your next oil change or annual and drill safety wire holes in those screws. Be sure to replace those star washers any time you loosen an item that uses them. It's super cheap insurance to prevent a potentially catastrophic failure.
Rob Brooks
EAA Tech Counselor
Warrenton, VA
RV-8, QB completed, flown 750hrs and sold
http://www.taildraggersinc.com/pages...RV_flying.html
RV-7, SB completed and flying Phase 2
http://www.mykitlog.com/N908rv/
Old 11-19-2007, 10:55 PM
az_gila's Avatar
Exclamation Safety wire
Apparently the older carbs. used safety wired washers before the change to those little bent tab washers..
Safety wiring sounds like a better approach to me too... looks like they are 1/4-28 X 7/8 from the parts manual - should be easy enough to get some cap screws with drilled heads, or even slotted screws with drilled heads...
gil A
Gil Alexander
Old 11-20-2007, 12:21 AM
zkvii's Avatar
zkvii zkvii is offline
Sorry for the thread creep.... Can I ask a 'dumb' question on this issue...
Could slightly longer drilled shank bolts be used and the safety done on the 'upper' side of the bolt.
Is safety wiring the shank of a bolt a no no?
I can't find a supplier of UNC 1/4" drilled head (or shank) 'aircraft' bolts - I was assuming grade 8 commercial would be used.
Carl
ZK-VII - RV 7A - New Zealand - NZNE - 700 hrs (2008 -2020)
http://www.rvproject.gen.nz/
TMX OF-360 (FADEC), Dual GRT H1, Garmin 430 / SL30 / 327, TT VSVG
Old 11-20-2007, 04:27 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default socket heads
My approach will be to use drilled socket head screws at this location. Easy to find, and easy to drill and wire. Anyone else considered this??
Regards,
Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 11-20-2007, 05:02 AM
mahlon_r mahlon_r is offline
gil A
In my experience, the screws have gotten loose because the bowl gasket shrinks, not because of poor locking devices.
Good Luck,
Mahlon
?The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 11-20-2007, 06:04 AM
Ironflight's Avatar
VAF Moderator / Line Boy
I don't have .01% the experience that Mahlon does, but I think I like his explanation. I had the bottom half of my carb come loose in the same way on my Grumman (many years ago), and the lock tabs were still tight up against the screw heads. None of the screws had turned or pulled out - it MUST have been the gasket.....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
