Old 11-18-2007, 04:53 PM
dustman dustman is offline
Default Horizo stab
Question for the experts. With all the measuring and double checking i still screwed up on the alignment of th hs. Vert its ok, but its skewed about 3/8 of an inch forward on one side. Is this going to be a problem I did not catch it untill all the holes were drilled for both hs and vs.
Old 11-20-2007, 01:53 PM
jlfernan's Avatar
jlfernan jlfernan is offline
How did it become skewed? I'm getting ready to mount mine on my 9A and I'm assuming the HS is square since it is all prepunched and if the two vertical bars that the rear HS spar bolts to were square, then the HS should end up square.
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 11-20-2007, 02:37 PM
TerryWighs TerryWighs is offline
It may be helpful to call Vans tech advisors on this one????
RV-8 builder..."Reindeer Man"
Fairbanks, Alaska
http://www.mykitlog.com/twighs
empennage done
Wings done
Fuselage kit 90% done...
Old 11-20-2007, 03:11 PM
N941WR's Avatar
N941WR N941WR is offline
Terry is right on, check with Van's.
Which RV are you building? I suspect the airplane will never know the difference but again, check with Van's.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
