Paul.... this was basically the original routing on the early RV-6A drawings.
The vertical location was not well defined....
... and probably was intended to be above the lower longeron angle and through the bottom of the bulkhead.
It also showed a side exit just in front of the wheel, rather than the vertically down exit you have.
Since the overhead pedals were in the early RV-6As, pedal interference should not be a problem. The central cover was only introduced on the -7/9 models... the -6s had a battery immediately behind the firewall... the brake line for the opposite side had to run under, or in front, of the battery...
Perhaps some old -6A web sites might show this early routing...
UPDATE
Found on Gary Zilik's site....
gil A
