Originally Posted by plehrke
If I put 8 qts in my 0-360 I get a rapid reduction to 6 quarts in under 10 hours. It is all most likely coming out of the breather as the belly gets plenty messy. When it gets down to 6 quarts it stays there until my next oil change and the belly is much cleaner. I actually now only put in 7 quarts at oil change and then add the 8th quart at around 18 hours to keep it above the 6 quart line on the stick. I call that "no oil consumption" as I only use 8 quarts total for the oil change cycle.
2 quarts in the first ten then stays at 6 for the remainder of the oil change. So during the last 15 to 40 hours (depending on 25 or 50 hour interval) the engine consumes none. 15 hours, zero oil consumption. I believe that.
Second scenario: Seven quarts at oil change, 1 quart 18 hours later to keep it above 6 quarts so I must assume it dropped to 5 or 5.5 quarts or you would not have added oil. So thats 1.5 to 2 quarts used in 18 hours yet you say "no oil consumption". Hmm. Must be new math.
My engine uses the first quart more slowly than the second. I dump 8 in at oil change and about 10 hours later I have to put another quart in as the stick is on 7. At 20 hours I'm sitting at 5.75 on the stick but don't usually bother to add oil since the oil change is only 5 hours away. Probably use another .5 to .75 quarts in the last 5 hours. So that gives me a consumption total of 2.5-2.75 quarts in 25 hours. Old math.
So as you can see, when we're hangar flying and talking about oil consumption we're comparing apples to oranges.
