Old 11-15-2007, 08:10 AM
prkaye prkaye is offline
Default Removeable floor
I'm going to make all my floors removeable (mainly because this avoids the need for another "pre-cover inspection" as required by Canadian rules). Next week I'm going to be assembling the center fuselage, with all those floor ribs. Question, do I need to put all the nutplates on the floor ribs now, or can that be done later, after it's assembled and I'm ready to put the floors in?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 11-15-2007, 08:22 AM
You can. But why would you want to? I did it AFTER the ribs were installed and the one problem I had was getting at the underside of the rib to debur. Minor thing, yes, but still frustrating.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 11-15-2007, 09:15 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Phil,
You can do it either way you want. I think you will find, however, that in the long run it will be a much easier and faster job to go ahead and install the nutplates on the individual ribs now while you are seated on a stool at the workbench as opposed to waiting until after the ribs are installed and then finding that access and installation convenience is significantly diminished by comparison.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 11-15-2007, 09:57 AM
chaskuss chaskuss is offline
Phil,
The fastest way is to IGNORE the instruction to rivet the floor ribs to the rear spar now. Leave everything clecoed. Once you have all your skins drilled and clecoed on, fit the floor skins with the fuselage upside down in the jig (or sawhorses). Once the floor skins are drilled and clecoed on, take EVERYTHING apart for deburring and dimpling.
Are you going to use #6 or #8 machine screws to hold down the floors??? The rest of my advice will vary depending on what size screws you use.
Regardless of screw size, you can drill and fit the nutplates to the floor ribs while the ribs are out and apart. After you drill, deburr, dimple, (Alodine if desired) & prime you floor ribs, you can install "most" of the nutplates before reassembly. This will take some head scratching prior to disassembly, because some of the nutplates must be left off for now. Premature installation will impede or prevent easy riveting of the ribs/skins during reassembly.
Charlie Kuss
Old 11-15-2007, 10:02 AM
Was thinking #6 to save weight, but maybe #8 would be easier to work with, and the weight difference would be negligable? Recommendations?
Phil
RV9A (SB)
Ottawa, Canada
Old 11-15-2007, 11:05 AM
vlittle's Avatar
vlittle vlittle is offline
Hey Phil. Why not just make a couple of access panels that are screwed down to the floor?
I put my strobe PSU underneath one, and the other is just for inspections. That way it's a few platenuts rather than dozens. Your MD-RA inspector can view your internal handiwork with an inspection mirror.
Platenuts and screws are unneeded weight if you never plan on removing the floor. A couple of well-designed panels will give you all of the access you need. When I added a flap limit switch, I drilled out some rib tooling holes for snap bushings using my right angle drill through one of the panels. No problem.
Vern
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 11-20-2007, 08:09 PM
Default nutplate not fitting
For putting the nutplates on the floor ribs (to make the removeable floor)... there's one spot where the nutplate won't fit... one side of the nutplate overhangs the edge of the flange. What did you guys do about this?
Photo attached...
Phil
RV9A (SB)
Ottawa, Canada
Old 11-20-2007, 08:31 PM
Kevin Horton's Avatar
Phil - I bought some one leg dimpled nutplates to solve that exact problem. I think I have a few left over if you need them. I'm on the road right now - I should be back on Thursday.
Kevin Horton
RV-8
Moses Lake, WA, USA
http://www.kilohotel.com/rv8/
Old 11-21-2007, 03:50 AM
Photo attached...
Phil
Use a "one leg" nutplate for these areas. I had to use several of them. Are you planning on pan head screws or flat head screws for retaining the floor skins?
Per your earlier question, I asked the same thing of my local RV guru, Jody Edwards. Jody said that his experience (25 + years as an A&P/IA) he found that #4 & #6 screws sometimes would break when you attempted to remove them. He said this didn't happen with #8 or larger screws. I used #8 flush screws on all my flooring. In retrospect, flush screws offer no advantage along the left and right outer edges of the floor skins. These areas will never have seat cushions on them and your feet will never be placed in those areas.
I can send you photos of my floor skins with the nutplates attached if you desire. What model RV are you building?
Charlie Kuss
Old 11-21-2007, 04:25 AM
Rick6a's Avatar
......there's one spot where the nutplate won't fit... one side of the nutplate overhangs the edge of the flange. What did you guys do about this?
Nutplates come in many, many variations. In this situation, use a single leg nutplate also known in some circles as a "one lug anchor nut."
http://www.aircraftspruce.com/catalo...anchornuts.php
I used #6 and #8 truss type screws because they are easier to install and service. Besides, when the rear seat is in place, the only exposed screws are around the perimeter of the floor anyway.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
