There has been a lot of LED (high current) sources mentioned in this thread:
http://www.vansairforce.com/communit...ad.php?t=14888 Which most deliver those high current LEDs you wish to find from superbrightleds.com.
And the site you mention, the most of their LEDs are just normal LEDs, not anything special we look for. Those mentioned to be 1 Watt or so might be something, but likely they will be beaten by many other. Like those have worse viewing angle than many other high current LEDs which leads easily to higher intensity so don't get fooled...
For good reference you should look for
www.lumileds.com (look for K2 and Rebel -types) -- they put good reference line in terms of intensity, size, temperature handling, price etc... so if you find something better, please let us know!
PS. As you may guess, there are lot of different kind of manufacturers in China. Some of them you may contact them directly and save some bucks and the list is 'end-less'
http://www.made-in-china.com/ There you may find something less good with less money. Not necessarily bad option.
