We started our 0-360 a couple of days ago but it sure ran ragged. It ran fine for a few minutes but on the second startup it got more and more ragged. We found a bad plug (brand new Autolite) and replaced it but it still ran ragged and wouldn't go over 1500 RPM. If I advanced the throttle at that RPM, it died, as though it was going really lean. It barely idled and I suspected trash blocking the jets so we drained the bowl and a couple of small pieces of rubber (fuel hose?) came out. This is a freshly overhauled carb by Precision in Miami but I took the float bowl off and looked at what passages I could see and blew air through them but it still runs ragged and won't go over 1500RPM or so. Any advice? We also tried enrichening the mixture with the mixture screw but to no avail.
Pierre RV6A...almost airborne..
