  #11
Old 11-12-2007, 02:03 PM
Norman CYYJ Norman CYYJ is offline
I would be doing a very short full power run up before I ever took the plane into the air. How else are you going to know if there are any problems with the engine. The first few feet in the air is a terrible place to find out the engine has a problem. Also a short taxi out to the runway at or just above idle will not hurt your new cylinders. Also it will make sure the oil has started to warm up. Taking off with low oil temps can also cause engine damage. Have a good safe flight.
Old 11-12-2007, 02:58 PM
N941WR's Avatar
N941WR N941WR is offline
Pete,
After a few hours, check the torque on the exhaust, intake, and valve cover bolts. Do that again at 50 hours, again at 100, then every condition inspection.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-20-2007, 09:08 AM
Tram Tram is offline
Well guys -
She flies.. We got to fly her yesterday and were able to put about an hour on her before we had other obligations to tend to..
Everything went off without a hitch!
Old 11-22-2007, 06:33 PM
wv4i wv4i is offline
Default ECI recommendations
ECI has some very specific guidance re break in of new cylinders, see guidelines. 25 hrs since teardown on my RV-6, new cylinders, pistons, etc., and O-360 engine runs great.
Link McGarity
Wellington, FL (FD38)
RV6/N42GF bought flying, sold
RV6/N72AT bought flying, sold
B737-800/NxxxAN
Sonex TD w/Aerovee/N732SX bought flying
Old 01-07-2008, 05:49 PM
Just curious guys - does anyone know how long the regimen of keeping the engine at say full throttle for 10 minutes and then another throttle setting at 10 minutes, etc must go on before the plane can be flown like "normal?"
We currently have right at 6 hours on the new cylinders...
Old 01-07-2008, 06:42 PM
Just run your engine at 75% in cruise till the oil consumption stablizes. At this point drain the oil and refill with AD type. Then fly it anyway you want to. The engine will be broken in.
