Testing the panel to see all is well...but....When everything is powered up....D-100/Ems120/GMA 340/GNS 430W/SL 40/GTX 327/Trio ALT Hold/Trio Easy/..........and I push the PTT button the Dynon D-100 Screen goes black
As I trobleshooted the problem I found that if the Trio's are off/SL40 is off/GTX 327...or combination of instruments shut down this wouldn't happen. Power is being supplied by a 15 amp/13.v RS power supply.......
I would assume that the power supply isn't giving the necessary amps especially at the break point of PTT being used. It would seem that the Dynon is the first to note the deficiency and thus shuts down (internal battery is also discharged so it can't help).
I will call the folks at Dynon Monday to get their take....but....I was hoping you folks would have a notion as to the problem or give me backing on my assumptions!!!!!
Thanks in advance for you imput
Frank @ sgu NDY but I see light.............
