Old 11-09-2007, 08:42 PM
cjensen's Avatar
cjensen cjensen is offline
Default Need pics of behind the panel tip up jettison
I'd like to see some pictures from those of you that installed the tip up canopy jettison behind the panel. I'm not sure yet if I am going to install it at all, but if I do, it's not going on the panel, but at the sub-panel.
TIA!
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 11-09-2007, 08:52 PM
N941WR's Avatar
N941WR N941WR is offline
Chad,
Check out these pictures:
I did cut the tab off later on.
For more details, check out the 4/23/06 entry on the 2nd fuselage page of my web site.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-09-2007, 08:59 PM
cjensen's Avatar
Quick response Bill! Thanks, those pics help immensly! I never gave that way of installing it a thought. I like it!
Chad Jensen
Old 11-10-2007, 10:42 AM
When I first started this part of the canopy project, I figured, "sure, I'll put it in, why not?"
Now that I've built -- pretty much -- the rest of it, my only thought is "are you kidding me?"
The little ground-down bolts (now "pins") are handy for taking the frame on and off for the 10 zillion times you have to do it at this stage, but once I built the rest of the frame and fit the canopy and all, I realized what a joke (again, this is only my opinion) the whole concept of an in-flight canopy jettison is. First, the only reason I'd do it is if I had a parachute. That's not likely. But, second, it seems to me that even if I could fly the plane while getting the canopy jettisoned (doubtful), everything has to go perfectly when it finally blows. And maybe it will...but it also seems likely it'll take my head off or, if I'm lucky enough to get that far, it takes out my VS.
So the advantage of it, it seems to me is getting it quickly off on the ground. Well, if it's an emergency landing, being an "A" and all, I'm probably going to be upside down. So that's not going to work. And I can more easily accomplish getting it off by banging the **** out of it with a heavy tool, which I think I'll use in exchange for the weight penalty of the Van's system.
To me, there's a whole lot of weight there, with no real good reason.
But, again, that's just me. I certainly respect the decisions of others.
Bob Collins
St. Paul, MN.
RV-12iS Powerplant kit
Old 11-10-2007, 11:36 AM
cjensen's Avatar
I agree completely Bob. The only reason I'm still considering putting it in, is simply for ground maintenance. I like Bill's setup behind the panel. I am still just considering putting it in at this point because of the weight penalty.
Chad Jensen
Old 11-10-2007, 11:44 AM
I wonder, though, once a canopy is complete and on the frame, how often folks find themselves removing it?I have no answer for that, of course.
Bob Collins
St. Paul, MN.
Old 11-10-2007, 11:59 AM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I put the mechanism in, but not the rip out channels by the hinges. I never intended to jettison the canopy, but the ease of removing the canopy was worth it to me. I turned the handle so it is horizontal and does not get in the way of the avionics. Anytime I need to work on the back of the panel (which admittedly is not often) it only takes seconds to remove tha canopy. One pull as I left up from the inside and Rich lifts from the outside. And I'm sitting in the seat instead of standing on my head.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 11-10-2007, 06:59 PM
Norman Donaldson Norman Donaldson is offline
Default Tip up canopy
I have a flying RV6 with a tip up canopy. The hole in the IP Panel I thought was objectionable. Bill Repucci's photo shows partly what I did. All my part numbers are for RV6. Bill's picture shows a tube extending down from belcrank Wd-619. I added a second hinge block at the bottom of panel F-668 spacing it out with a bracket like channel F-697 and added a second pivot block to support the end of the tube extension. I took Lever Wd-618 and overlaid a wooden handle on the long part of the lever attaching it with two screws and nuts. I attached it to the lower end of the tube extension with a single bolt thru the lever and tube and secured it with a nut. Wih my canopy pivots locked the handle is pointing left just clear of the bottom edge of the sub panel by about one inch. To release the hinges I push the handle forward. I have removed my canopy several times since I started flying and would strongly reccommend keeping this feature in some form or you will live to regret it. I have had many problems keeping the P-strip rubber seal in place on the front bulkhead. MY latest attempt was to remove the the two sided self stick tape from the P-strip using a solvent like naptha to clean the surface and I mounted it using 3M Super Weatherstrip Adhesive Yellow. This job is easyest done with the canopy removed. Sorry I did not photograph these parts during constuction.
Norman Donaldson
normanjd@aol.com
RV6 with 74 hours
Old 11-10-2007, 07:11 PM
Mel's Avatar
Mel Mel is offline
If you don't intend to use the canopy jettison in flight, then Bill's method is the best. I have installed several that way. BTW, the canopy jettison will not work in flight if you have the lift struts. The struts were not a part of the original RV-6 design.
I personally wear a chute when doing acro. I do not have, and will never have the struts. But that's a personal thing.
The weight of the jettison mechanism is minimal.
I've had my canopy off probably 4 or 5 times in the last 15 years.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-10-2007, 11:18 PM
danielhv's Avatar
danielhv danielhv is offline
might be pointless, but it looks cool having a handle on the panel that says "CAUTION: CANOPY JETTISON" Its kinda like having that famous red button you never get to push...
"What ever you do... DONT PUSH THE RED BUTTON!!!"
