Originally Posted by Harold Lanfear
Mark,
Thanks for the idea; I'd been toying with that but not sure how to align the pins and sockets without wear. You've solved that and more.
Can you add some detail how you positioned the plugs while you epoxied them in place? That would be most helpful.
snip
Harold
Harold,
I wish I had taken more photos during the fitting.
I installed the connector on the stick side first. I used a mating DB9 with the "ears" still on it to but up against the end of the tube. This positioned the connector inside just flush. I "packed" some foam rubber about 1" from the connector inside the tube through a hole that I had originally made to run the wires out the side. This was to keep the epoxy from running out. You can't see this hole in the photos. I turned it connector up and carefully poured "dobbed" the epoxy down and around the connector.
The next day after the stick connector was in place I placed the connector for the reciever with wiring onto the stick. I used ivory soap as a mold release. Smearing it in the places I didn't want the epoxy to stick. I carefully slid this assembly into position into the reciever and poured about an inch worth of epoxy inside. I had smeared some RTV silicone around the wires where they entered the backside of the connector so the epoxy wouldn't run inside the connector.
I hope this description of the process helps. But I'm sure there are many ways to end up with the same result.
Mark
