Old 02-28-2019, 12:21 PM
scsmith scsmith is offline
Originally Posted by KayS View Post
I am close to install the whell pants on my 7. I intent to land on gravel/grass strips later and understand that a larger tire (like the 380) should help in that regard. On the other side i hate to throw stuff away and the installed stock tires do look perfect. So my questions to the guys who switched to larger tires: Is it really a noticable improvement during TO/landing on grass/dirt strips?
Kay
Yes I would say it is a very noticeable improvement. Especially noticeable on dirt, but also on grass.
Steve Smith
Aeronautical Engineer
RV-8 N825RV
IO-360 A1A
WW 200RV
"The Magic Carpet"
Hobbs 625
LS6-15/18W sailplane SOLD
bought my old LS6-A back!!
VAF donation Jan 2020
Old 02-28-2019, 12:57 PM
rocketbob's Avatar
Even in the case of normal sized 500-5 tires that don't have an excessive out-of-round condition, I believe the overlap is the root cause for wheel shake. Every time the tire rolls over the heavier overlap section the stiffness of the tire changes and I believe it's enough to cause oscillation.
Bob Japundza CFI A&PIA
N678X F1 Rocket, under const.
N8155F C150 flying
Not a thing I own is stock.
Old 03-04-2019, 08:02 AM
flyinggreg1 flyinggreg1 is offline
Originally Posted by Pilot135pd View Post
What size are you using on the rear ?
I have on backorder from Flyboys their 8" Condor pneumatic. Right now have the stock tailwheel.
Old 03-04-2019, 02:24 PM
Pilot135pd's Avatar
Pilot135pd Pilot135pd is offline
Yes, I'm also on their waiting list for the 8" as soon as it comes available.
RV-8 N52VM: OnSpeed Gen2 AOA-3D, Dynon D-180, Autopilot, Titan 0-360A1A, Hartzell C/S, INS-429 IFR & GPS496, WingX & Stratux for backup & ADS-B IN. Enjoying life while building an airpark with FREE campsite for pilots www.facebook.com/VacaMooAirport/
Exempt by 3 out of the 10 ways but I still donated.
Old 09-03-2019, 10:37 PM
mratzburg mratzburg is offline
Default Does tire brand make any difference in shimmy?
I have had gear shimmy occasionally on my RV-6 with the stock tires. Some of you have reported problems with shimmy changing to the larger tires - is there any difference in shimmy between the tire brands in the 380x150-5 size? Or is just luck of the draw as to whether or not you get a good set?
