Old 11-08-2007, 06:10 PM
rv4dude rv4dude is offline
Default transfer "rivet" pins???
Does anybody know of a source for transfer pins that are in a shape of a NAS1097 reduced head rivet (Oops rivet) or a standard flush rivet? It's not for a RV project, but still needed. Google has not revealed anything, figure this is the best place to ask for help.
Old 11-08-2007, 09:19 PM
Transporter Transporter is offline
Default Transfer Punches?
I'm familiar with three types of transfer pins/punches for standard rivet sizes:
1. Cleaveland sells a set of seven transfer punches sized for standard rivets. See http://www.cleavelandtoolstore.com/p...sp?number=TPS7
2. They also sell strap duplicators (so do Avery and other vendors).
3. Brown also sells individual transfer punches.
I'm not aware of any for 'Oops' rivets...don't they just use the next larger size rivet hole? Or do you have another purpose in mind?
Regards,
Mike
Mike Dooley
RV hitchhiker
RV8 SB
VAF#1067, EAA Chapter 91
Old 11-08-2007, 09:54 PM
az_gila's Avatar
az_gila az_gila is offline
Question This?
Are you thinking of a hole transfer pin like this?
From the Yard....
http://www.yardstore.com/index.cfm?A...ry&Category=56
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-08-2007, 11:26 PM
Default not yet...
The ones I'm looking for look just like a 5/32" NAS1097 (reduced head) oops rivet. They are made of steel and have the transfer point on top of the head. I need to take a picture and post it. I have a few in hand but I need a bunch more. I don't know where they came from and I sure can't find anything on them yet. PLEASE, keep trying!! I know this is the best place for help!!
Old 11-09-2007, 05:20 AM
Rick6a's Avatar
Rick6a Rick6a is offline
I use em all the time and here's a thread I started which should point you in the right direction. One of the links has a source of the 5/32" size you seek.
http://www.vansairforce.com/communit...ad.php?t=11999
This relatively recent update to the original thread illustrates how quickly I was able to drill out the canopy skirt using transfer punches:
http://www.vansairforce.com/communit...ad.php?t=19643
Good luck.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
