Old 11-07-2007, 11:11 AM
szicree szicree is offline
Question carb temp probe gasket?
Should there be one? Any sealant?
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 11-07-2007, 12:15 PM
tx_jayhawk tx_jayhawk is offline
Steve,
TO prevent galling, a dab of fuel lube should be put on the threads. A lock washer is also recommended to account for potential vibration.
Scott
7A Finishing
Old 11-07-2007, 04:35 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Lock washer only
A check of EI's installation manual says...
http://www.buy-ei.com/Manuals/EI%20MVP-50P%20II.pdf
Remove the threaded plug located in the carburetor housing just below the throttle valve. Install the Carburetor Temperature Probe (P-128) in this hole using a lock washer. Care should be taken not to over-tighten the probe, thereby stripping the threads in the carburetor housing.
Apparently it's a straight 1/4-28 thread....
P-128 Carb Temp / OAT Probe, 1/4" -28, Type K. Used on most engines.
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
