Old 11-06-2007, 04:35 PM
jmartinez443 jmartinez443 is offline
Default Closing QB wing with blind rivets
I'm about ready to close my QB wings and was wondering if anyone has ever used blind rivets to fasten the outboard lower skin. Would this be considered a no-no?
Jorge Martinez
QB 8A Fuse. Just battled the ^%&@ing gear weldments. Now I can move on.
http://www.rv8alog.com
Old 11-06-2007, 04:40 PM
Mel's Avatar
Mel Mel is offline
Default Not A Problem!
Blind rivets are acceptable almost anywhere on the RV except for the main wing spar. I've inspected many RVs with the lower wing skins blind riveted as you suggest. Many of these have been flying for well over 10 years.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-06-2007, 04:46 PM
Ironflight's Avatar
VAF Moderator / Line Boy
As Mel says, you certainly can do the outboard panel with blinds...but it really only takes a couple of three or four hour sessions with a partner to use solids - and it's quicker on the second one!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-06-2007, 04:50 PM
Default WOW
Now that is what I call a quick reply. Thanks Mel. If I may bother you with one more stupid Q: I've already dimpled one of the skins for AN426AD3 rivets, would it be acceptable to use MK-319-BS (after I ream out to 7/64" of course).
Thanks in advance.
PS Do you DAR outside of TX? If so, I'll be calling you in about a year
Jorge Martinez
Old 11-06-2007, 07:07 PM
az_gila's Avatar
az_gila az_gila is offline
Smile Yes...
Thanks in advance.
Yes, it's OK... see this parallel thread.....
http://www.vansairforce.com/communit...92&postcount=5
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 11-06-2007, 07:11 PM
Mel's Avatar
Mel Mel is offline
The MK-319 rivets will work fine in the 100 degree dimpled holes. These rivet heads are so close to the AD3 heads that you'd be hard pressed to see a difference.
Yes, I do go outside of Texas. I've done quite a few airplanes in Kansas, New Mexico, Colorado, Oklahoma and Arkansas.
Old 11-06-2007, 07:28 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Yes, I do go outside of Texas. I've done several airplanes in Kansas, New Mexico, Colorado, Oklahoma and Arkansas.
Mel has been one of the best, most absolute advisors I have ever dealt with in regards to build questions and real true honest answers. Your money would be well spent having him sign off your project. And, no... this is not paid advertisement! Just the plane truth!!
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 11-06-2007, 09:07 PM
jeffmoreau's Avatar
jeffmoreau jeffmoreau is offline
I have never heard of using blind rivets to fasten the skin. I would use solid rivets. Some of them are difficult to buck, but it can be done. This is best accomplished with a partner.
Jeff Moreau
RV 8A
N888JM/Flying
EAA Technical Counselor
Virginia Beach, VA
Old 11-07-2007, 12:56 AM
Pirkka Pirkka is offline
Obviously money is not problem as those pop rivets cost a lot compared to solid rivets. Price for MK-319-BS at Van's is $0.22. Pneumatic pop-rivet tool might be nice as well... The builder is different from us anyway as building for RV-8A.
Pirkka
- RV-7 -
Tail: Waiting for fiberglass.
Wings: Some priming left, then lot of riveting.
QB Fuse + Finishing kit: in crates.
Old 11-07-2007, 09:18 AM
Time vs Money the eternal paradox. I'm always inclined to follow the path of least resistance. That's why I bought a QB, that's why I'm building an A (no TW time or desire to get transition), blind rivets where I can to save time and labor, and yes, I do own a pneumatic rivet puller
Even if I needed 500 of them (which I won't), it would only cost about $100. This is a $70k plane (conservatively). Peanuts compared to the PITA it's gonna be to buck all of those solid rivets. Besides, it's the bottom of the wing - who'll ever know ... oh, I guess you guys will. The shame
Jorge Martinez
