Go Back   VAF Forums > RV Firewall Forward Section > Propellers
  #11
Old 11-08-2007, 08:36 PM
rvbuilder2002's Avatar
Default Summed up...
Originally Posted by Rosie View Post
Both Russ and James could be correct...but that depends on what your operating limitations say. I switched from FP to C/S prop in 2005. My operating limitations (dated June 2000) did not allow me to do what James described as the verbage allowing this was not included.
I contacted the local FSDO and their response was to issue me new operating limitations. The new limitations had the verbage to allow me to remove my fixed pitch prop, install the constant speed prop then put the plane back into Phase I for at least 5 hours flight testing (all done with complete annotations in the log books).
All FSDO contact was done via phone and snail-mail as I had to send in a copy of the limitations issued to me Rosie
Paul summed it up...
Recommending what an RV owner must do in this type of situation is impossible. In the past 20 years a number of different versions of operating limitations have been issued. The operating limitations are the first thing any RV owner should look at when the have any regulation related question about their RV.
BTW if you have old operating limitations you can request to have them reissued to the latest version (even if you are not making any changes to the airplane at that time).
Scott McDaniels
Hubbard, Oregon
Old 11-08-2007, 08:49 PM
N908RV's Avatar
N908RV N908RV is offline
Default Centreville, VA
Originally Posted by carguy614 View Post
BTW..Born and raised in Centreville Va. Understand it's a little bigger now!!
Chris,
Boy, you ain't kiddin' !
Rob Brooks
EAA Tech Counselor
Warrenton, VA
RV-8, QB completed, flown 750hrs and sold
http://www.taildraggersinc.com/pages...RV_flying.html
RV-7, SB completed and flying Phase 2
http://www.mykitlog.com/N908rv/
Old 11-08-2007, 10:07 PM
jclark jclark is offline
Default Thanks Paul, you are correct ...
I **should** have mentioned that "in theory, consistent with your documented operating limitations ...".
James
James E. Clark
Columbia, SC
RV6 Flying, RV6A Cowling
APRS
Old 11-09-2007, 07:34 AM
Mel's Avatar
Mel Mel is online now
Default Read your operating limitations closely.
Even with the latest operating limitations, you must "notify the geographically responsible FSDO of the location of the proposed test area. The aircrat owner must obtain concurrence from the FSDO as to the suitability of the proposed test area. If the major change includes installing a different type of engine (reciprocating to turbine) or a change of a fixed pitch from or to a controllable propeller, the aircraft owner must fill out a revised form 8130-6 to update the aircraft's file in the FAA registry."
For a short time (around 2002), operating imitations were issued without this requirement.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-09-2007, 09:11 AM
Rosie's Avatar
Rosie Rosie is offline
Location: I live in on the Rosamond Skypark (CA) and am married to Victoria (Tuppergal).
Mel, my (new) limitations dated February 2005 do not have any of the above wording in them.
My original limitations, issued by the Van Nuys FSDO in June 2000 had roughly 10-15 'General Limitations', another 10-15 for 'Phase I' and exactly 2 limitations for 'Phase II'. They read something like "1.) All General limitations apply and 2). Experimental indicator & FAA passenger warning placards must be visible to the passenger."
Operating Limitations, unfortunately, vary state to state, FSDO to FSDO, inspector to inspector... Rosie
Paul A. "Rosie" Rosales
Rosamond Skypark (L00), CA
RV-6A, 4200+ hours since 7/4/2000
Old 11-09-2007, 09:18 AM
Mel's Avatar
Yes Paul,
Unfortunately they do. However, they are NOT supposed to. FAA Order 8130.2F states EXACTLY how they will be issued. Unfortunately some FAA guys don't keep up with the rules.
Regardless of what is supposed to be, the operating limitations issued for a particular aircraft are "binding" for that aircraft.
Old 11-09-2007, 02:30 PM
N941WR's Avatar
N941WR N941WR is offline
Mel,
As I read this, should I change my Catto prop for another Catto prop, I still have to notify the FSDO and go through all this? I can't just put it back into Phase I, do my five hours, and make the log book notation?
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
