The "P" lead should read "open-to-ground" with the switch in the "mag on" position and should read a "short-to-ground" in the "mag off" position. The switch shorts the mag to ground to disable it.
The reason to do this check without the mag connected is that you will get different readings depending on whether the points are open or closed in the mag.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
