Old 07-06-2005, 09:11 PM
Default Fire Extinguisher Mount
At Sun 'n Fun when the three Judges were inspecting my plane one of them said "Can you reach that fire extinguisher back in the baggage compartment in case of an inflight emergency?" I was somewhat trapped but I said "yes" thinking if there is a fire I would get it someway. Regardless, it was not a good situation which I am sure cost me points but even worse it is an unnecessary risk. I had been carying one in the side pocket but the top came off while it was rattling around in there with the flashlight extra batteries, miniature chocks and rudder gust lock pins/RBF Flag (they are held on with internal plastic tabs - Halon RT A600 in the Aircraft Spruce catalog). Anyway after conceptualizing placement I decided that between the seats would be best. I made a little aluminum box type pedestal 1.625" high mounted it on a plate with flush screws from the bottom (into platenuts) and mounted the plate on the control tunnel cover with the existing screws. Worked out very well.
Bob Axsom
Old 07-07-2005, 06:28 AM
n250jg n250jg is offline
Default -8/8A Fire Extinguisher Location Option
In our -8A I mounted it on the back of my seat. Out of the way of both pilot and pax and I can get to it easily. Before you start drilling holes be sure to test the location and make sure it's easy to get at when you need it.
Something to be aware of though (and I still need to correct)... when my brother (a fireman) came to Houston to help us get ready for inspection, he said the extinguisher needs to be installed so the nozzle is oriented down or level, not up so debris can be lodged in the opening to block it.
Good luck,
Jeff Gross
N250JG RV-8A (#81185)
"Object of Desire"
Amarillo, TX
Old 07-07-2005, 01:36 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Inflight use of fire extinguisher
Has anyone ever heard of a fire extinguisher being successfully
used in a small aircraft in-flight? I plan to have one easily
accessible, probably mounted just like Jeff's.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 10-11-2006, 10:17 PM
petehowell's Avatar
Default Fire extinguisher mount in a 9 or 7?
Where are people mounting fire extinguishers in 7's and 9's? I have an Amerex 344T Halon Unit.
Pete
Amateur Radio - KD0CVN
Doggies Delivered - 25+
St. Paul, MN
Old 10-11-2006, 11:16 PM
vlittle's Avatar
vlittle vlittle is offline
Hi Pete, me again.
I mounted mine on the right side baggage compartment flap linkage housing. make sure when you mount platenuts that they don't interfere with the underlying fuse structure.
In flight, the pilot can reach over and release it.
Bob Axsom's location is ok... but it might be susceptible to accidental discharge.
Make sure you amend your W&B, since you've already weighed things.
V
Old 10-12-2006, 05:37 AM
N941WR's Avatar
N941WR N941WR is offline
Don't know if they have been used in flight but there are a number of stories about them being used "in taxi" and a number when they were not used with loss of the plane.
I would just as soon have one as not. Besides, they might give you an extra few minutes to get on the gound.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-12-2006, 06:47 AM
Scott Will's Avatar
Scott Will Scott Will is offline
I just mounted mine on the doghouse that covers the high-pressure fuel pump on the injected engines. Thought about mounting between the seats but then thought someone might step on it or something. So mine is on the angled, front portion of the doghouse.
Seen others mounted on the arm rests.
Scott Will
http://will2fly.com
CFI - CFII - MEI
FLYING RV-7A IO-360 @ KPDK
Old 10-12-2006, 06:49 AM
Low Pass's Avatar
Low Pass Low Pass is offline
Halon mounted under the right canopy rail, adjacent to the front seat. Occupies almost no usable/useful cockpit space.
Bryan
Houston
Old 10-12-2006, 07:04 AM
Mel's Avatar
Mel Mel is offline
Couldn't mount mine between the seats because of manual flaps. Mine is mounted to the floor left of pilot's seat.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-12-2006, 10:53 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
For my -9 I've been thinking under passenger legs attached to the forward (fuel line) cover . It seems like a good location that is very easy to reach and that would be less intrusive to passnger legs than the gear weldments are on the nosewheel versions. To be sure, I'd probably re-fab the cover on that side out of thicker stock. Any thoughts on the pros or cons of this location?
Thanks.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
