Originally Posted by Bob Collins
One thing. Be VERY careful when you go to buck those outboard (errr....up and down) rivets. If you're not careful with the bucking bar, you can gouge the doubler bar up something fierce. Lots of duct tape to protect the bar is advisable. It's a real tight fit under there.
Thanks for the tip, Bob. I'll remember to tape it up. I'm planning on using my back rivet set, so hopefully the bucking bar (held by my wife) will not be moving at all--it will just serve as the back rivet plate. Insurance in the form of tape is a good investment.
I just did the countersinks on those two holes for each wing. I took my cage off my countersink mechanism (easily removed) and did the first one. My one hole countersink cutter is very aggressive and I took out more than I needed to on that first hole (though not so big that I need to use a 1/8" rivet). For the other three holes, I actually just used my deburring bit (not the countersink cutter at all). That worked the best of all. Three out of four perfect isn't too bad, especially since those rivets only attach the platenuts.
Thanks again for the help.
