Old 11-02-2007, 09:47 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default carb offset question
Hi all...
9A with superior XP 0-320. Getting ready to do up the airbox, and have discovered that there is a great deal of left hand offset with the carb in relationship to the cowl. About 2 inches. Centering it all up will not clear the cowl, and I barely have enough room below the airbox, so it looks like I won't be able to fit the filter bypass, if it clears at all. Looks like I will have to offset the upper filter plate on the square bore carb to fit vans airbox. The carb is a lot longer than all other -4 carbs that I have seen, so a lot of upward crank on the airbox neck will obviously be in order. I am wondering how other builders have solved this issue. Bump out the cowl??? I hope not...
Thanks in advance...Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 11-02-2007, 09:57 AM
Mel's Avatar
Mel Mel is offline
The offset in the carb is to enable the prop to be centered on the aircraft with the right thrust of the engine. To accomplish this the rear of the engine had to be shifted to the left.
Make the cowling fit the engine.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-02-2007, 02:03 PM
mahlon_r mahlon_r is offline
All O-320 carbs are the same length. Are you sure you haven't got an O-360 carb by accident? If O-360 carb, the M/N is MA4-5 and P/N 10-3878 or 10-4164-1 instead of an O-320 Carb that is a model number MA4-SPA. The O-360 carb is a few inches longer then the O-320 carb. The offset of the mounting flange, for the carb, on the bottom of the sump, is normal and exists on all vertical Lycoming sumps.
Good Luck,
Mahlon
"The opinions and information provided in this and all of my posts are hopefully helpful to you. Please use the information provided responsibly and at your own risk."
Old 11-02-2007, 05:20 PM
N941WR's Avatar
N941WR N941WR is offline
Originally Posted by carguy614 View Post
...so a lot of upward crank on the airbox neck will obviously be in order. I am wondering how other builders have solved this issue. Bump out the cowl??? I hope not...
Chris,
This is normal. The one O-320 powered -9A in the area had to turn the snout to the right and bend it upward to line up with the inlet.
FWIW, on my O-290, this was about the only thing that worked in my favor. Other than canting the FAB towards the opening, it was a straight run. Of course, my MA3 carb is a good bit smaller than your MA4.
BTW, this should go fairly fast. It sounds like you are really moving along!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-02-2007, 07:46 PM
joeboisselle joeboisselle is offline
I just discovered this on my -4 this evening...(i had to buy a new cowl ) if the lower cowl isn't level it will offset the air intake significantly. On my first cowl () I attempted to cut and re-fiberglass the air intake on the cowl to the air intake/filter thing... that don't work! Mel's got it, make the cowling fit the engine. And, if you can, six hands work better than two on the lower cowl.
Joe Boisselle
2010 RV-4
1941 Luscombe 8C
Old 11-03-2007, 04:29 AM
carguy614's Avatar
Default carb offset maybe wrong carb
Good Luck,
Mahlon
Hi Mahlon.. Indeed my carb is marked MA4-5 PN 10-3878 so it may be the wrong one. Are you sure about these numbers?? If so, I guess a call to Superior will be in order.
Thanks a million...Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
RV9 in progress
