Old 11-01-2007, 08:38 PM
Geoff
Posts: n/a
Default Mold Release / Wax
Well, I'm halfway through phase one and it's time to finish the wheel pants and intersection fairings -- even though flying is a lot more fun.
Can I get some opinions as to what type of wax and/or mold release works best to go between the modeling clay and the fiberglass?
Spray on? Wipe on? Get it from Spruce or the local hobby store? Anything else?
Thanks.
-Geoff
RV-8
Old 11-01-2007, 08:50 PM
Rivethead Rivethead is offline
I'm pretty much a novice but I've recently taken a fiber glass class (Synergy Air) and we used PVA. That's PolyVinyl Alcohol and seems to work really well all by itself. I ordered mine from Spruce and while online also ordered a can of mold wax. PVA cleans up with soap and water, you should use several coats alowing it to dry before recoat. It's a brush on.
Old 11-01-2007, 09:32 PM
SportAvServ SportAvServ is offline
Default Mold release
I get a paste from my local (tap plastics) plastic and fiberglass supplier, never had a problem with the real stuff, car wax doesn't work, had a problem with that.
Old 11-01-2007, 11:19 PM
RWoodard's Avatar
RWoodard RWoodard is offline
I'd suggest spraying the PVA mold release on. I use an old non-HVLP touch-up gun that has been laying in the back of my tool cabinet ever since I bought a decent HVLP touch-up gun.
The as someone else says, the stuff is water-based so clean-up is a breeze. I usually spray 3-4 coats. I bought mine from Spruce.
For clay layups, I don't use any wax for mold release--just the PVA.
Rod Woodard
Brighton, Colorado (CO12)
RV-3 N87CT (Thanks Chuck!)
Glasair 1RG N388DM
RV-3 N99RV sold 01/2000
F1 MkIII empennage?arrived 08/22/2018--collecting dust
