There is a trap- don?t fall in!
There is some rational to putting the flow restrictor at the firewall and using the aeroquip hose as a damping ballast. However, there is an inherent trap in the assembly that should be avoided. The problem is that the torque of the AN-4 flair fitting should be a good deal more than what you want for the aluminum 1/8?NPT fitting you are screwing into the cylinder head, but there is no space for a wrench to prevent it from turning. If you are tempted to stop tightening the flair because the fitting starts turning on the pipe threads, the flair fitting will not be tight enough. That hose is constantly being worked by engine vibration, AND IT JUST MIGHT FALL LOOSE!
The workaround is non-conventional assembly using three wrenches. Use a 5/8 and 9/16 to hold both the hose and flair nut from turning. Put a drop of medium locktite on the flair fitting threads, screw it into the flair nut and securely torque it with a 1/2? wrench while still holding both parts of the hose end fixed. Next, put some thread compound on the NPT threads and very carefully screw it into the cylinder head. Use the 9/16 wrench on the flare nut to gently but firmly torque the fitting into the head. Ideally, also try to find a way to stabilize the hose to the engine a few inches away from fitting. On my installation the hose was really too long connected to #3 so I moved it to #1. I then was able to use the oil return line on #3 to loosely stabilize the hose there.
Otis Holt-
RV-7A (bought)
Built Monnett Moni
Frmr Test Pilot/Author CAFE APR's:
RV-8A, S-7C, Europa, Glastar.
-2019 VAF donation!!-
"RV-Fun is inversely proportional to RV-Weight!"
