Old 11-01-2007, 05:39 PM
Phil's Avatar
Phil Phil is offline
Default Sweat and Oil
At last I have an aircraft part. The VS is completed and only god knows when I will get back around to touching it again.
Before I put it away for (X) years, I'd like to remove some of the sweat and hand oils off the surface of the skin.
What's the best stuff for it? I thought about MEK, but thought that might be over the top.
Is there something you like to use? Preferrably something that cuts the oil and evaportates cleanly.
Phil
Old 11-01-2007, 05:54 PM
N908RV's Avatar
N908RV N908RV is offline
Default MEK or acetone
Don't worry about it too much.
I always get a chuckle when folks worry about little scratches and the like, because just before you get ready to paint the entire aircraft it is scratched up with scotchbrite and sandpaper.
Same with the oils from your hand, don't sweat it - pun intended. Just clean it off with acetone or MEK - it won't hurt the aluminum any. I find that acetone is better as MEK can leave a bit of residue.
The bigger thing - try to keep it in a place with lower humidity if at all possible and of course out of the elements and the VS that you committd blood, sweat and tears to will be just fine.
Happy Building,
Rob
Rob Brooks
EAA Tech Counselor
Warrenton, VA
RV-8, QB completed, flown 750hrs and sold
http://www.taildraggersinc.com/pages...RV_flying.html
RV-7, SB completed and flying Phase 2
http://www.mykitlog.com/N908rv/
Old 11-02-2007, 05:41 PM
rv8guy's Avatar
rv8guy rv8guy is offline
lauquer thinner -cheaper, smells a little better, not as nasty
Marshall Jacobson
"Miss Sue"
RV-8 80749 slow build taildragger
7.5 year build first flight Dec 2005
SOLD at 540 hours and 10 years of FUN
N68AK
Watkinsville, Georgia
Old 11-02-2007, 06:14 PM
harleyl harleyl is offline
Water with a little rubbing alcohol will remove sweat
and body oils. Prep All from the Bondo section at Wal
Mart is a good wax and grease remover. Prep All is also
one of the best precleaners prior to priming and painting.
Hope this helps, Pat
Old 11-02-2007, 11:17 PM
Captain_John's Avatar
I have been using isopropyl alcohol in an atomizer bottle and it works well!
It dries fast and clean. No harmful what-do-ya-callits and it smells nice!
CJ
The experiment works!
Old 11-02-2007, 11:33 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Other stuff
Originally Posted by N908RV View Post
The bigger thing - try to keep it in a place with lower humidity if at all possible and of course out of the elements and the VS that you committed blood, sweat and tears to will be just fine.
Rob
...and where your neighborhood cats can't come in and mark their territory in a dispute with your cat...
gil A
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
