Old 11-01-2007, 04:40 PM
TomH TomH is offline
Default N number details: size, color, font
Size, color requirements for exterior N numbers and any help with where to order, these are for before paint and DAR inspection. Thanks
Old 11-01-2007, 06:00 PM
MrNomad's Avatar
MrNomad MrNomad is offline
Default n-numbers
Experimental a/c need numbers that are 3" and larger.
I am about to order 3" numbers from:
Marilyn
AeroGraphics
800-336-9633
She said: The 3" numbers are $15.00 plus shipping. If we send in the mail the postage will be $4.00.
I have never worked with them before and so I cannot report on the quality.
Barry
Old 11-01-2007, 07:37 PM
chrispratt's Avatar
chrispratt chrispratt is offline
Super Moderator
Default Marking sizes
3" numbers are okay for the RV series. I can't remember the exact FAR but I believe anything with normal cruise under 180 knots can use the 3 inch markings. Above that you need to use 12 inch.
Aircraft Spruce and similar suppliers sell stencils for this purpose. Some have a long lead time so order early. You might order two sets in case you're going to use one pre-paint and then will need another for the paint shop. I think most paint shops will do this for you although if you have a particular syle you like you might want to provide your own stencil.
Chris
Chris Pratt (2020 VAF DUES PAID)
RV-8 Flying, 850+hours
N898DK
Lycoming O-360-A1A, Hartzell CS
52F (Northwest Regional, Aero Valley, Whatever, TX)
Old 11-01-2007, 07:49 PM
RV6_flyer's Avatar
Check http://www.rvdar.com/FAR_45.htm
There are links to the FAA FARs in the above summary.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 11-01-2007, 08:24 PM
Mel's Avatar
Mel Mel is offline
BTW,
Numbers may be 2" on RV-3 since the design is over 30 years old. Also you may exclude the "experimental" placard by placing an X in the N number. i.e. NX168TX. See FAR part 45.22 (b).
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 11-01-2007, 08:30 PM
L.Adamson's Avatar
L.Adamson L.Adamson is offline
Default 2" Experimental on fuselage sides?
A DAR required a friend of mine to place those 2" Experimental decals under the sliding canopy on each side of the plane (RV9A), as "required" in your link to the FARs.
Seems that most RV's only have the decal on the baggage bulkhead. I wonder what the deal is. In the case of the 9A, it isn't painted, and I don't believe these decals will survive a paint job.
L.Adamson
Old 11-01-2007, 09:03 PM
Geico266's Avatar
Geico266 Geico266 is offline
One of the benifits of living in a state that starts with the letter "N" is I can use the Nebraska Cornhusker's "N".
http://j.b5z.net/i/u/2048250/i/left_wing.JPG
Yes, the FAA has seen them. No, I did not need to take them off...yet. Yes, I carry spares just in case some rule reg FAA FISDO gestopo type makes me take them off. Yes, I hope we fire the head coach and start over.
RV-7 : In the hangar
RV-10 : In the hangar
RV-12 : Built and sold
Old 11-01-2007, 09:05 PM
macrafic's Avatar
macrafic macrafic is offline
Another twist. Under all circumstances, your N number must be 12" or larger in order to fly into any of the ADIZ areas, no matter what year or type of plane you are flying. You are allowed to display them temporarily, such as with duct tape.
Rich and Cindy Macrafic
Rochester, MN
Flying
Old 11-01-2007, 09:07 PM
JHines JHines is offline
Originally Posted by Mel View Post
BTW,
That is awesome - too bad it can't be done with the newer models - NX - whatever - makes you feel like Charles Lindbergh!
Jonathan Hines
Charlotte, NC
Old 11-02-2007, 07:14 AM
the_other_dougreeves the_other_dougreeves is offline
The CT dealer's DAR (TUL area) required 12" numbers and even a change from a serf font to a sans-serif font. He indicated that the Feds have been pressing him hard to have plain N numbers. YMMV.
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
