Old 11-01-2007, 01:32 PM
Capflyer's Avatar
Capflyer Capflyer is offline
Default External Power Source
What are others using for an AC supplied external power supply so you do not run the battery(s) down. I have a battery power unit for jump starting the plane and it supplies 12V for basic stuff but does not have enough juice or time to effectively allow me to work with my EFIS and program my EIS system.
Mike R.
Mike
JAMES AIRCRAFT.com
Flying - RV8 Hot Rod "Drone Killer"
Flying - RV8 "Look'n Good"
RV4 - FAST & FUN! Rebuilt, Flown, Sold
RV-7A Built, Flown, Sold
Old 11-01-2007, 03:00 PM
the_other_dougreeves the_other_dougreeves is offline
Might try a 12V power supply like an Astron. They can be set to put out 11-15V (or 22-30 if you want a 24V version). Available in many different outputs, with or without volt and amp meters, linear or switching mode versions. Available at Ham Radio swapmeets everywhere. I have a RS-12A that's run for over 10 years.
TODR
Doug "The Other Doug Reeves" Reeves
CTSW N621CT - SOLD but not forgotten
Home Bases LBX, BZN
Old 11-01-2007, 03:56 PM
Guy Prevost's Avatar
Guy Prevost Guy Prevost is offline
I use a 13.8V, 20A power supply from Pyramid. It's Chinese, but seems to do the trick. There are better 13.8V power supplies out there for sure.
Guy Prevost
Albuquerque, NM
RV-8a Built, Enjoyed, Sold
Two Kids: Built, Enjoying
RV-10, Bought, Rebuilt, Enjoying
Build / First Flight Video: http://www.youtube.com/watch?v=8f9HXzZT1dE
Build Log: http://websites.expercraft.com/geprevo/
Arguing on the internet is like having a competition to see who can hit a brick wall the hardest. You may win, but you're still an idiot.
Old 11-01-2007, 04:19 PM
penguin penguin is offline
Default Old PC power supply
Take the power supply out from your old PC, google the pin outs for the large 20 pin mother board connector and figure out which wires to connect to a switch to make it produce power (its been a while since I did mine), then take your pick from several 12v outputs. I'm told that its possible to tweak the output up to 13 or 14v, but I haven't figured that bit out yet, 12v has proved enough for me for the time being.
Pete
Old 11-01-2007, 04:54 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I started out using a tiny little 6 amp 12v power supply I had laying around, but once I wanted to start all-up testing, I needed more....went with a big Pyramid, and love it - great for shop/tech power whenever I need it.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 11-01-2007, 10:02 PM
BuckWynd's Avatar
BuckWynd BuckWynd is offline
Mike:
I have a Samlex SEC1223 power supply, available here:
http://www.radiodan.com/misc/samlex1223.htm
I'm very happy with it. It's small, and rated at 23 amps continuous -- enough to run everything in the average RV.
Buck Wyndham
Northern Illinois
RV-8 N18XL
