10-31-2007, 11:14 PM
Painting your RV
I am planning on building an RV-10 and am looking into what it takes to paint your own aircraft. I cant find much on the subject. can anyone recommend a website, thread or book that will help me with the required skills.
thanks
10-31-2007, 11:35 PM
Painting
I'm on my 3rd complete airplane paint job, and the best advice I recieved was from a fellow pilot that owns a body shop. So far I prefer Sherwin Williams Jet Glo top coats and primers. After all of the techniques that I have tried, the best for me is one light coat, 15 minutes later a wet coat. Having said that, there is a lot to the preperation of the metal or fiber glass, use the AC43-13 and read up. Stick to one brand of paint, the primers, topcoats and clears play together well, and I have found cheap automotive paint is just that. And NEVER get in a hurry.
Randy
11-01-2007, 06:22 AM
VAF Moderator / Line Boy
thanks
You might already have looked through the "Painting" sub-forum, but if not, take a look....a wide range of threads, topics - and opinions!!
http://http://www.vansairforce.com/c...c&daysprune=-1
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
11-01-2007, 07:02 AM
Jet-Glo
Got to go along with Randy about Jet-Glo. My -6 was painted with Jet-Glo almost 15 years ago and still looks great.
Back then Jet-Glo was made by Pratt & Lambert but to my knowledge, Sherwin Williams has not changed the formula.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
11-01-2007, 07:46 AM
painting
Just one reccomendation... Paint the belly before you roll over the canoe. Saves a lot of time later..
FWIW...Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
11-01-2007, 10:52 AM
But
Painting upside down is so much fun...er..Not!
Frank
11-01-2007, 12:24 PM
thanks for the advice guys. ill try to get to the paint area when i get back to my hooch. the computer police got it locked out here! anyone know any good books on the subject?
11-01-2007, 12:28 PM
Senior Curmudgeon
I cant access it from my home, no computer police involved.
Maybe a bad link??
I will see if I can post another link.
Got it.
http://www.vansairforce.com/communit...sprune=30&f=75
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Reason: add link
11-01-2007, 03:02 PM
Preparation and cleanliness are key to a good paint job. The prep is the hard part. Painting is easy.
Here are a couple of tips.
The fuselage makes the best wing holder.
and
The best way to paint the bottom surfaces is with a creeper and pressure fed paint gun.
I have sometimes thought of making and step by step tutorial on painting an RV with pictures and stuff but seems to be a whole lot of work. I still have my own RV to build and thats enough work already.
RV-8A builder
A&P mechanic
Aviation Plasticized Pigmented Polymer Application Engineer
11-02-2007, 06:22 AM
My 2 cents
I'd never painted anything before I did my RV-6. It was a lot of work, but it was worth it. My advice is to not skimp on the equipment. Buy good stuff and you won't regret it. I started painting mine with a (relatively) cheap gun and compressor, but after dissatisfying results, bought a semi-professional gun, a big 60 gal compressor, and even an air dryer/filter for the painting line. I also bought good paint (SW Jet-Glo). Now that its over, I'm glad I did it that way.
Also, I would disagree with some of the previous posts about how to paint the pieces. I painted everything prior to final assembly. It wasn't hard to make jigs for the wings, fuselage, etc. and have easy access to all sides of them.
Good luck.
Jordan Grant
RV-6 N198G
Monthly donation started Mar '20
