Old 10-31-2007, 09:53 PM
Pmerems's Avatar
Pmerems Pmerems is offline
Default Anyone know why the gear length change between 6A to 7A/9/A
Just wondering if anyone knows the history behind the change in gear length from the 6A to the 7A/9A.
I compared the tail heights between the 6A and 7A at the Copperstate Fly-In this past weekend. The tail height of the 6A's were approximately 6 feet while the 7A's/9A's were almost 8 feet. That is a rather substantial change.
I know the rudder is a bit taller but the majority of the difference is in the gear leg lengths.
What is the reasoning behind the change?
Dream it, Build it, Fly it
Paul Merems (EAA Tech Counselor, EAA Sheetmetal Workshop Instructor/Volunteer 12 yrs)
ExperimentalAero-HANGAR BANNERS
www.experimentalaero.com
RV-7A (Flying since 2010)/RV-4 (sold 1990)
Tucson, Arizona 85749
Old 10-31-2007, 10:11 PM
PCHunt PCHunt is offline
Default Just a Guess
I'm going out on a limb to hazard a guess: The longer Main Gear is to lessen the chance of touching down on the nose gear first.
Flame suit on.
Pete Hunt, [San Diego] VAF #1069
RV-6, RV-6A, T-6G
ATP, CFII, A&P
2020 Donation+, Gladly Sent
Old 10-31-2007, 11:03 PM
vlittle's Avatar
vlittle vlittle is offline
I have the answer from Gus Fennell at Van's:
"because it looks better"
That's it.
V e r n. ====
RV-9A complete
Harmon Rocket complete
S-21 wings complete
Victoria, BC (Summer)
Chandler, Az (Winter)
Old 11-01-2007, 03:45 AM
hevansrv7a's Avatar
hevansrv7a hevansrv7a is offline
Default Horsepower means prop length
I didn't ask Van's but I always thought that allowing 20 additional HP meant the need for a longer prop which in turn needs more clearance. I would have been just as happy with shorter legs!
H. Evan's RV-7A N17HH 240+ hours
We can lift ourselves out of ignorance, we can find ourselves as creatures of excellence and intelligence and skill. We can be free! We can learn to fly!" -J.L. Seagull
Paid $25.00 "dues" net of PayPal cost for 2015, 2016, 2017 and 2018 (December).
This airplane is for sale: see website. my website
Old 11-01-2007, 05:09 AM
N941WR's Avatar
N941WR N941WR is offline
One other thought...
The 7A & 9A have a longer fuselage, thus you would need longer gear legs to keep from hitting the tail on landing.
With the -9, you need longer gear legs than the -7 to get the wing to stall in the landing attitude.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 11-01-2007, 05:34 AM
gmcjetpilot's Avatar
gmcjetpilot gmcjetpilot is offline
Default The reason could lay in the TD's gear change?
May be the reason for the taller Trike gear is the tallier Tail Dragger Gear?
The Trikes are related to the TG's. The TD level attitude (tail up) was looked at I'm sure. Van looked for some parity between the two gear types, height wise.
Changes to the Tail Dragger version has obvious affects. Ostensibly higher angle of attack in the three point attitude allows slower landings. Another advantage is more prop tip to ground clearance. The RV wing is such a low speed loving monster its impossible to fully stall in ground effect with out hitting the tail wheel first, even with the taller gear. A full stall landing means hitting the tail wheel first, with mains still a foot or more off the ground. This makes a somewhat inelegant "drop it in" technique with little or no advantage over flying on a few MPH faster. The down side is less forward visibility.
The affect of taller gear on the trike is somewhat the same as a TD, in that you can be at a higher angle of attack with the tail tie-down ring in the dirt. Of course with the main being set back further on the fuselage it does no need to be as tall. Also you do get more prop tip to dirt clearance. Taller trike gear makes it harder to climb in and out, with a low wing. The reason is it looks better is probably also a reason. The other down side is more flexable longer gear. That may be a disadvantage with the nose gear which some call a poll vault.
George
Raleigh, NC Area
RV-4, RV-7, ATP, CFII, MEI, 737/757/767
2020 Dues Paid
Old 11-01-2007, 06:52 AM
rvpilot's Avatar
rvpilot rvpilot is offline
Default Effects of taller gear
Not sure it looks any better, really not sure it would be any more likely to drag the tail. Sure looks like it may be easier to transfer a lot more weight to the front in a given situation though! Throwing it out for comment!!
Bill Waters
Based KCVC (Covington, GA)
RV6A - Gone, but not forgotten!
RV8 - Gone too, now winning races in the RV Gold Class!
RV4 - Flying!!!
Old 11-01-2007, 07:10 AM
plehrke's Avatar
plehrke plehrke is offline
Default 6A look better then 7A
That's it.
I do not think the taller tail looks better. I think the 6A looks better with the 5 degrees nose high attutude. Looks more like a tail dragger.
Philip
RV-6A - 14+ years, 900+ hours
Based at 1H0 (Creve Coeur)
Paid dues yearly since 2007
Old 11-01-2007, 07:28 AM
GrayHawk's Avatar
GrayHawk GrayHawk is offline
The tail dragger crowd is always telling us how their planes (with tail on the ground) look 'cool'. So it stands to reason, 'coolness' is the inverse of tail height above ground. Then it follows that a 6A is more 'cool' than a 7A or 9A.
GrayHawk
My rebuild log: http://www.cherryfamily.net/bill/n63tx/rebuild/
Texas Hill Country Hangar For Sale: http://www.myspicewoodhangar.com/default.htm
Old 11-01-2007, 07:46 AM
Sam Buchanan's Avatar
been here awhile
I have considered the same thing. Haven't most of the nose-over accidents involved the newer models?
Sam Buchanan
RV-6
Fokker D.VII replica
