Old 10-30-2007, 08:39 PM
collinsj57@adelphia.net collinsj57@adelphia.net is offline
Default Cold air stopper
I have gone through two cold seasons trying to stop the cold air coming from the cheap eye ball vents and I finally found the way to do it. Works perfectly!!! Went to Lowes aircraft supply and bought two “1 ½ inch test plugs” $2.79 each, They are the type of plug you insert into a pipe and turn the fly nut to tighten. a rubber seal expands and they stay put until you want to remove them. Fits perfect and I can not detect any air coming in. How simple and cheap.
John Collins
South Central PA
RV6A Phase II
Old 11-07-2007, 08:06 PM
Jekyll Jekyll is offline
Can you provide a picture?
Jekyll
Old 11-07-2007, 08:17 PM
tomwebster's Avatar
tomwebster tomwebster is offline
I have an air diverter on my Van's supplied vents.
It comes nearly to the edge of the eyeball vent
and wouldn't let anything to be plugged in there.
The only thing I have had any luck with is a foam
plug.
Tom
Tom Webster (Chox)
VAF-134
Columbus, Ohio
Luscombe 8A/E (sold after 35 years)
RV-7A N462TW (315 hours)
CX4 (under construction)
Friends of the RV-1 http://www.rv-1.org/
Old 11-07-2007, 09:08 PM
Build9A's Avatar
Build9A Build9A is offline
Default ditto
"ditto" on the picture request. sounds promising.
RV9A N489JE - Flying
Eagle Neck Airpark
Shellmans Bluff, Georgia
Old 11-07-2007, 09:19 PM
Default I wil try and get a pic this weekend
If you just ask for a 1 1/2 inch test plug at lowes they will show you where they are. Was up last weekend and they work great!!!!
John Collins
South Central PA
RV6A Phase II
Old 11-07-2007, 09:29 PM
Build9A's Avatar
Default is this it?
check out this link. Is this what you are describing?
http://www.doityourself.com/invt/u457796
Eagle Neck Airpark
Old 11-07-2007, 09:32 PM
Bryan Wood's Avatar
Bryan Wood Bryan Wood is offline
LOL
Yeah your right about them working great, but...
My wife came up with that idea a couple of years ago and we've been using them in the winter. They do work great but be ready because one day you will be cruising along on a flight and as you relax and let your mind drift a bit, "WHAMMO." The dumb thing will shoot out of the vent and hit you in the gut. This will scare the livin you know what out of you. To prevent this make a tether or you will be reporting back with how you were frightened by this while your passenger which in my case was my wife laughs herself into stomach cramps.
Edit- For those who haven't tried the bathtub stoppers they only fit the vent really well with the vent fully open. If the vent is closed the little finger tab will not let the stopper get deep enough into the eyeball to stay. For this reason the pressure will sometimes get the better of the plug and shoot it at you. After this happens once though it doesn't have quite the shock value.
Best,
Bryan 9A Sold
Beech S35, and daydreams of a Super 8 or a Rocket starting to take over my brain.
Old 11-08-2007, 06:22 AM
DaX's Avatar
DaX DaX is offline
That's what I'm imagining he is using.
http://flyingtodhunter.livejournal.com
RV-7 Wings, Tail, & Tools FOR SALE
Old 11-08-2007, 06:42 AM
FrankK90989 FrankK90989 is offline
Default Snap on
Turned mine from 1/2" poly
Frank Karasti
Hibbing, Mn
RV-9A
Flying--------->-
Old 11-11-2007, 08:08 AM
Default Thats it
"That's what I'm imagining he is using."
The only differance, the ones I bought are red plasic otherwise thats what I,m using.
John Collins
South Central PA
RV6A Phase II
