Affixing the fuel float to sender
I have the fuel float all adjusted, but how do you affix it to the sender so that it doesn't flop arouhd? I mean, the float will rotate about the axis of the wire that is inserted into the sender. How do you hold it in place? Proseal???
Also, when installing the drain value, does one use some kind of sealent or something like teflon tape?
Thanks.
Jeff Rosson
Repeat Offender
RV14 - Working on Empennage/Tail Cone
RV9A - Completed! First flight on July 18, 2012!
Based at Merritt Island, FL (KCOI)
VAF Number: 1170
Star Trek Quote: "Logically, it could work. Also, logically, there are a hundred variables, any one of which could put us in a worse position than we're in now." Mr. Spock in Return to Tomorrow
