Old 10-28-2007, 04:02 PM
jlfernan's Avatar
jlfernan jlfernan is offline
Default Cherrymax Not Set Right
Putting a Cherrymax rivet in a tough spot. The mandrel seemed to break early. The madrel extends too far out the back and is not flush on the head side. What would be the cause of this? Too long too short a rivet? Or, operator error? I managed to drill it out. Sorry about the photo qualty, but you can see how far out the mandrel sticks out. The spot is where the subpanel attaches to the bulkhead. Using a Cherrymax guage it indicates a -2 but you can see how the rivet reacted.
[IMG][/IMG]
http://www.mykitlog.com/JorgeF
Jorge Fernandez
Spruce Creek, FL
Old 10-28-2007, 06:05 PM
jlfernan's Avatar
Also, I know on solid rivets a certain amount of the rivet extends out through the hole. With a Cherrymax rivet, how much should it extend out?
Jorge Fernandez
Spruce Creek, FL
Old 10-28-2007, 06:15 PM
Geoff
Posts: n/a
Try this link for everything you ever wanted to know about Cherry rivets. Instructions, animations, specifications, troubleshooting, etc.
http://www.cherryaerospace.com/html/...indrivets.html
Old 10-28-2007, 06:25 PM
WilburD2 WilburD2 is offline
Default Broken early
Jorge, every time I've ever used Cherry's, the reason the shaft wouldn't go flush is the rivet being too long. Since the shank is wrinkled all the way up that seems to be the case here. Also, the cheerymax shank will break off if too much a side load is on the shank when your pulling it. Finally, a properly pulled cherry on the back side will be nicely rounded. The base of the shank will form a perfect little cap over the opening the shank caused
Bill S.
A+P, RV Dreamer + Schemer
RV-9 preplans in hand
Old 10-28-2007, 07:35 PM
jlfernan's Avatar
Smile
Hey Bill,
It worked! I made sure this time there was no side load on the rivet and it came out perfect. Thanks for your help.
P.S. Can you give me some advice on how to drill the holes for the HS attach brackets prefectly perpendicular...
Jorge Fernandez
Spruce Creek, FL
Old 10-29-2007, 03:29 PM
RV7Factory's Avatar
RV7Factory RV7Factory is offline
Chief Obfuscation Officer
Page 17 of the Process Manual was interesting. It says that if you want to install a CherryMax in dimpled sheet, you should ream the hole smooth (a diagram is included). My question is, how do you do this? Not how do you ream, but how do you drill, dimple then ream (e.g. what sizes) to eventually end up with a dimple with smooth walled holes? If you drill and dimple #30, the hole will stretch and you can't then ream it with #30. Maybe the answer is that for us (RV builders) it isn't critical, but I am curious.
Brad Oliver
Livermore, CA | RV-7 | SOLD
RV-7: RV7Factory.com | iPhone app list: AviatorApps.com | Photography: BradOliver.com
Old 10-29-2007, 05:05 PM
GAHco's Avatar
GAHco GAHco is offline
Default Oversize Rivets
CR3242-4 is oversize for the CR3212-4
The 3242 uses a #27, which will clean up a dimpled#30 hole real nice.
Have Fun!
Get em in the Sky!
Tom Brink Pres.
GENUINE AIRCRAFT HARDWARE Company
www.gen-aircraft-hardware.com
www.gen-aircraft-hardware.com/site_tips.asp
28th Anniversary of GAHco March, 2012
Thanks for being part of our success
Dues Paid November 2012
Old 10-29-2007, 05:13 PM
Default Straight holes
[quote=
P.S. Can you give me some advice on how to drill the holes for the HS attach brackets prefectly perpendicular...[/QUOTE]
Most every one will agree with me, if you have the room with the brackets, a drill press with the piece gently clamped to the table to keep it from moving and squared to the drill bit..
Bill S.
Old 10-29-2007, 05:16 PM
RV7Factory's Avatar
Thanks Tom - Great info! I had a suspicion the answer involved the oversized versions, but I glad to hear it from an expert .
Brad Oliver
Old 10-29-2007, 11:20 PM
GAHco's Avatar
Default Your certainly welcome!
Thanks Tom - Great info! I had a suspicion the answer involved the over-sized versions, but I glad to hear it from an expert .
The subject brings to mind another kind of oversize application.
this would be even more likely in the RV realm.
I have had to put a cherry-max where a -3 countersunk rivet was.
In these cases I have used a smaller head countersunk CR3214-4-2 (shortest they come) and drilled out the hole normally dimpled for an MS20426AD3 rivet with a # 30 drill. Then taken the 100 degree countersink and knocked out about 5-10 thousandths from the inside of the countersunk dimple, installed the said cherry-max and gotten a decent replacement rivet, installed in a difficult to otherwise do spot.
Get em in the Sky!
Tom Brink Pres.
