Old 10-26-2007, 06:04 PM
RNewman RNewman is offline
Default New 2 Speed models of Safety-Trim available
Fellow RV builders,
We are pleased to announce that the new 2 Speed models of Safety-Trim are now available. Safety-Trim is an electronic controller for elevator and aileron trim servos that resolves the possibility of run-away trim conditions. Safety-Trim allows for greatly simplified wiring of Pilot and Co-Pilot trim switches.
The new models of Safety-Trim include 2 user adjustable preset speeds that allow you to select a high speed and low speed trim setting. The selection of trim speed is made via a simple switch closure and can be automated with an airspeed switch or flap position switch.
Please visit our web site: www.tcwtech.com to learn about all the features of Safety-Trim
Thank you,
Bob Newman
RV-10 #40176
Glastar N99RN
Old 10-26-2007, 06:20 PM
KTM520guy's Avatar
KTM520guy KTM520guy is offline
Ordered one yesterday.
RV-8A builder
A&P mechanic
Aviation Plasticized Pigmented Polymer Application Engineer
Old 10-26-2007, 06:24 PM
Thanks for your order. It shipped today.
Bob Newman
Old 10-29-2007, 10:10 PM
TimO TimO is offline
I'll post this to the 2 running threads that I found about this trim system.
Just for those who may be curious for more info or real-install stories, I just got done this weekend with the installation of the 2-speed 2-axis system and I'm very glad I installed it. The RV-10 trim was workable if you tapped it just fine, but due to how fast it could get out of whack if you unknowingly laid something on the trim switch, I considered it a real safety hazard to leave the trim set at full speed in cruise. (At slow speeds it's fine, and even great)
So anyway, enough for now but here's my write-up on the installation.
http://www.myrv10.com/N104CD/upgrade...027/index.html
Wish this would have been something I knew about the need for while I was building, and wish I would have installed it right away.
Tim
Tim Olson - CFI
RV-10 N104CD - Flying 2/2006 - 1400+ hours http://www.MyRV10.com
RV-14 N14YT - Flying 6/2016 - 350+ hours http://www.MyRV14.com
