10-26-2007, 12:28 PM
Hangar Door
Since I am putting my RV9A in my hangar, I guess this question qualifies as RV related.
I am looking at several options for hangar doors. They come with the door frame skeleton, motor, etc. and then you put the paneling on yourself or have it done. That way I guess you have color options and material options.
For those of you who have done this, what is the best material for the panels for the door and who are some of the material suppliers? thanks
RV9A N489JE - Flying
Eagle Neck Airpark
Shellmans Bluff, Georgia
Reason: typo
10-26-2007, 01:15 PM
Look at the 'Stack Door' made by Horton in Wellington, KS
10-26-2007, 03:33 PM
Use the same material that your hangar is sided with. It wil look nice and match the rest of the hangar. Mine is "R" panel steel, which is the most common.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
10-26-2007, 07:32 PM
Moderator/Tech Counselor
We have a Wilson Bi fold door and we have cedar siding on it to match the rest of the house. Wilson makes an excellent AL framed door that allows you to clad it with most anything. Ours has plywood and insulation with cedar lap siding over the top.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
10-26-2007, 07:58 PM
I can second the recommendation for a Wilson door--I put one on my hangar about nine years ago, and it has been completely trouble-free from day one. It wasn't the cheapest door, but I have seen problems with many other doors on the airport. It may help that mine is only 42', and the bigger ones seem to be more trouble.
If I were doing it again today, I would look carefully at the hydroswing, which I think is very interesting.
"Stack" doors also have their place, although they do limit the width of your opening. They don't need electricity, which is a plus.
James Freeman
RV-8 flying
Reason: typos
10-26-2007, 08:08 PM
Biggest problem I have with the Hydro-swing door is that you can't park anything close or the door will hit it. It takes a lot of room to clear the opening door.
If you do get one, be sure to get a window so you can check outside to make sure the way is clear.
I designed and built my first bi-fold hangar door and it's still working great after 17 years. My newer hangar has a Hi-Fold door. It still works great after 5 years.
10-27-2007, 12:50 AM
Ditto what Roberta said about Wilson. My new (15 year old) hangar has a Wilson. I've been working on it a lot lately (insulating, replacing old rubber etc) but the door itself (frame, cables, motor etc) have held up very well for 15 years.
Of course, it could be that Roberta and I live in Wilson's back yard...
Jeff Point
RV-6, RLU-1 built & flying
Tech Counselor, Flight Advisor & President, EAA Chapter 18
Milwaukee
10-27-2007, 05:55 AM
We have a 40' x 18' Hydroswing in our farm shop, and love it. Unless you are planning on parking a cabover truck right in front of the door, clearance is not a problem. Of them is the fact that you can put the windows practically anywhere, no hinges to work around.
We have a neighbor that has a similar sized bifold, and have a bi-fold in a hanger we rent from the city, wow, are they slow.
The biggest advantage of the hydroswing besides speed is the safety. The only way that they can come crashing down is if one of the cylinders breaks. If a hose or fitting fails, the door leaks down, taking about 30 seconds to close. We all know what happens when a cable on a bi-fold fails.
Go with a hydroswing, you won't regret it!!
10-27-2007, 06:42 AM
Not sure what you mean about "a" cable failing on a bi-fold door. My door has 5 cables any 2 of which will hold the door up.
Along with the fact, I've been around bi-fold doors for over 40 years and have never seen a failed cable. I know it can happen, just saying it is very rare.
10-27-2007, 06:59 AM
Hydro Swing Door
A neighbor had a problem here last winter when a Ice Storm froze the door to the ground. It took a lot of effort to clear the swing path to raise the door.
The Bi-folds came up much easier since it traveled straight up.
