Old 10-25-2007, 06:42 AM
celstar's Avatar
celstar celstar is offline
Default The best pre-heat system?
I'm looking for advice on which pre-heat system to install on my 7 here in Wisconsin? Anyone that has a system that they really like please tell me more.
Old 10-25-2007, 07:30 AM
painless painless is offline
I have a very simple system that I use.
I have a ceramic heater on the floor under the cowl that has an aluminum "plenum" of sorts riveted to it. From that, I run a length of aluminum dryer vent, the flexible kind, up to the cowl and insert it between the exhaust.
I plug this into a thermostat that is intended for heat tape to keep pipes from freezing. The thermostat is placed into the cowl through the oil door. Then plug the thermostat into an extention chord.
Then I place several blankets over the cowl and walk away. I keep this rig plugged in all winter and it keeps the entire engine compartment warm to around 40 F. When temps are in the teens, it runs maybe 3 times/hr and usually about 1-2 minutes each time. Engine starts up very easy. The thing that I will start doing, however, is doing about a half hour preheat with another ceramic heater inside the cockpit, as my electonics tend to say "yeah, right!" when it is cold.
REgards,
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 10-25-2007, 12:32 PM
ao.frog ao.frog is offline
Default This one maybe?
Hi.
Check out this website: www.aerothermheaters.com
Their heaters are not mounted on the plane. Doesn't add weight and complexibility. A definte + in my book...
Just my 2 c...
Alf Olav Frog / Norway
RV-7 Finishing
Old 10-25-2007, 12:45 PM
Kevin Nugent Kevin Nugent is offline
Some people are comfortable with a system that runs on a timer so on fri. night it turns on for that sat. morning departure. I like to be at least on the airport when I am preheating. I use the red dragon brand with excellent results. When I was a young man I learned a hard lesson on a fiberglass cowl(Citabria). I was not paying attention and was in the FBO hanging over the counter flirting with the new receptionist while my preheat was in progress. A little extra time lapsed and I ended up heating the top cowl into a melted mass. It had to be replaced. My Dad was not happy about that one. Be careful about those owner absent preheats.
Old 10-25-2007, 01:41 PM
stu517 stu517 is offline
i have the aerotherm for my cirrus and it works well.
sr22 driver - rv7 hopeful
Old 10-25-2007, 04:27 PM
frankh's Avatar
frankh frankh is offline
Default Stick on pan heaters from Napa
Mine are 100W total and keep the engine at 30F above ambient in my hangar with cowl plugs.
I keep mine plugged in all thime from October to March in Oregon.
Frank
Old 10-25-2007, 04:47 PM
Jerry Cochran's Avatar
Jerry Cochran Jerry Cochran is offline
Default Heater
Like Frank I live in western Oregon, and I put one of those $30 oil-filled ratidators right under the cowl exit. At the lowest setting it keeps the oil 25f over ambient. I just leave it on all the time because "they" say if you turn it on/off it causes condensation. Of course, my hangar rent includes electric...
Jerry
Old 10-25-2007, 04:52 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
I had a Tanis heater in my Cherokee and it really worked well. I also used one on my SeaRey with the Rotax engine. Very dependable and well made.
I have an insulated hangar and don't feel the need for a heater now.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 10-25-2007, 06:10 PM
I have the Reiff hot strip heater which glues to the sump. 200W total and installed on a timer so I can program when the thing comes on a few days in advance.
Combined with a couple of old towels stuffed in the intakes and a packing blanket over the cowl, it brings my oil temperatures to nearly 100f after 3-4 hours.
Of course, I'm hangared just north of Atlanta, so most of my preheat days have lows between the high 20's and about 45. Living waaay up north, your needs may be different.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 10-25-2007, 08:37 PM
Ron Lee's Avatar
Ron Lee Ron Lee is offline
Default Oil sump heater
Reiff I believe. Works well getting the temp up to mid 80s or so in a hangar with a blankie over the cowl top and inlet. I have a timer but since I can drive there in minutes I just plug it in the night before.
