Old 10-23-2007, 08:43 AM
cjensen's Avatar
cjensen cjensen is offline
Default Pipe tape on interior brake line fittings?
Do I need to pipe tape the threads on the AN fittings for my interior brake lines?
TIA...
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
Old 10-23-2007, 08:45 AM
Kevin Nugent Kevin Nugent is offline
No. I would not recommend that. Check AC 43.13
Old 10-23-2007, 08:54 AM
pierre smith's Avatar
Default Paste
Chad,
I would use Teflon based paste on all the pipe thread fittings, not on flared fittings. I don't see either tape or paste where your tee goes through the firewall into the reservoir. I used to use tape but pieces can break off and get in fuel/oil lines, etc, so now it's paste.
Regards,
Pierre Smith
RV-10, 510 TT
Air Tractor 402 PT-6-20 Sold
Louisville, Ga
Patrick Kenny, EAA 275132
Dues gladly paid!
Old 10-23-2007, 08:59 AM
Mel's Avatar
Mel Mel is offline
Do not use anything on the flare fittings. It's the flare that seals, not the threads. Use a thread sealant on the pipe threads.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-23-2007, 09:02 AM
Rotary10-RV Rotary10-RV is offline
TIA...
Chad,
AN 37? fittings were specifically designed to eliminate the need for sealants. If you have a problem, (that is a damaged fitting), Earls sells a specific conical repair washer. You shouldn't need, or use for that matter, a sealant on any of those fittings. I have done lots of break systems and never had the slightest trouble.
Bill Jepson
Old 10-23-2007, 09:43 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
Chad-
I understand that Bakerseal is a good, teflon-based sealant for the NPT threads. It is what I used. As above, only the NPT threads use it, not the flared fittings. As always, no teflon tape.
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 10-23-2007, 10:17 AM
cjensen's Avatar
Thanks guys! I'll grab some sealant from work, and put some on the NPT threads. There is nothing on them right now, they are just fitted.
Chad Jensen
Old 10-23-2007, 10:58 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Loctite 545 is designed for this use.
http://www.henkelna.com/cps/rde/xchg...el4=Industrial
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 10-23-2007, 02:24 PM
G-force's Avatar
G-force G-force is offline
Or 567. Its all we use at work for water, fuel, and oil systems on NPT threads. It is also an excelent anti sieze for stainless on stainless fittings.
Mike Sumner
Castaic, Ca
Old 10-23-2007, 03:46 PM
Sticky1's Avatar
Sticky1 Sticky1 is offline
Default Questionable
Questionable......
The flaired fitting does not need anything.....
The pipe thread however, well that's another story. Just MAKE SURE the manufacturer says that it is intended for a particular use. I have used the paste on fuel fittings and they leaked. Actually the paste broke down.
I put Teflon paste, Teflon tape, some brown plumbing stuff a plumber said was great, and rtv in a flat pan and filled it with 100LL. The Teflon tape was the only thing that held up for a day.....the rtv was good, the others ran.
