Old 10-22-2007, 07:42 PM
Steve Steve is offline
Default question connecting P-leads
I'm using Vans wiring harness and Slick mags. What is the proper technique to install the ring terminals to the shielded cable? The shielding doesn't get connected to anything, right?
Steve
Old 10-22-2007, 08:36 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Take a look at this page from Bob Knuckoll's site - it is pretty self-explanatory in terms of finishing off the shield wire. The core of the P-Lead goes to the P-Lead connection on the mag, while the shield goes to the ground screw on the mag. At least if I did it right....
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-22-2007, 09:21 PM
bfilarsky bfilarsky is offline
Paul
Sounds right to me, from what I've seen on other AC.
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW--What a Ride!" --Peter Sage
"Too many people are thinking of security instead of opportunity. They seem more afraid of life than death." --James F. Byrnes
RV-8 Empennage
Old 10-22-2007, 10:06 PM
az_gila's Avatar
az_gila az_gila is offline
Exclamation Add a short link wire...
The possible disadvantage of Bob's method is the strain put on the twisted shield at the exact point it leaves the cable... I've seen 2 P-leads broken at this specific point.
I prefer soldering a short jumper wire (black 18 g is good) to the shield, and then covering the exit from the cable with heat shrink.
The nearest picture I could find was this NASA preferred workmanship standard one...
I prefer the lower picture with the ground wire facing "backwards" and looping around, but either works...
This shows a twisted pair, shielded cable, but it's exactly the same for a single conductor shielded cable.
ADDED
I forgot to mention the quicker 75 cent method.. parts from Stein... a solder sleeve...
gil A
Paul ... use your NASA standard.....
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
Old 10-22-2007, 10:50 PM
N908RV's Avatar
N908RV N908RV is offline
I use Gil's method for P leads as well.
Although a number of certified birds you will see them just twist the shield into a wire, crimp on a connector and use heat shrink over it. This tends to get brittle over time though.
Rob Brooks
EAA Tech Counselor
Warrenton, VA
RV-8, QB completed, flown 750hrs and sold
http://www.taildraggersinc.com/pages...RV_flying.html
RV-7, SB completed and flying Phase 2
http://www.mykitlog.com/N908rv/
Old 10-23-2007, 06:54 AM
Thanks for the quick answers guys. The first place I looked was in my copy of Bob's book. Shoulda checked his site, too.
Steve
