Old 10-21-2007, 05:39 AM
tonyjohnson tonyjohnson is offline
Default landing gear mount anti corrosion
I recall reading a post here that recommeded a particular substance be used on the bare metal parts of the landing gear that fit into the metal sockets of the mounts. The purpose is to prevent the bare metal from rusting.
I can't recall the name of the substance and a search of the archives does not turn it up.
Does anyone know the name of that substance?
Tony Johnson
RV8A "Badboy" N12TJ
Treasure Island Florida
Old 10-21-2007, 05:44 AM
cytoxin's Avatar
cytoxin cytoxin is offline
Default uhhh huh huh
i call it grease, however someone may have mentioned cosmoline. like they store guns in and bury all over the middle east. you could paint where the gear is not touching the socket and just lube the machine spots where it does. ymmv
William Weesner/ still kicking.
Old 10-21-2007, 06:01 AM
gstone gstone is offline
Default Brayco 137 corrosion inhibitor??
This may be what you need, saw it listed for installing wing attach and center section? Actually name is Braycote 137!!
take care, greg
