Old 10-18-2007, 09:07 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default Idle Hands.....
Well, what do you do when you find a scrap of 1/8" aluminum and are standing in front of your band saw?!?
You make a couple of gas cap tools! I used the nylon one I bought from ACS a couple years ago as a pattern, cut two of them out of a tiny scrap of leftover thick angle, finish-shaped them on my Scotchbrite wheel, and polished them off to make sure there were no stress risers...
I know I'm probably taking food out of the mouth of whatever RV'er designed and sells the nylon ones, but it seems like I never have the right key ring in my pocket when I want to open the gas caps. Now with one on each key ring I own, I am much more likely to have one at hand! (And of course, one will end up on Louise's key ring...)
The moral? NEVER throw away scfraps....you'll eventually find something to do with them...
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 10-18-2007, 09:17 PM
KTM520guy's Avatar
KTM520guy KTM520guy is offline
Those pesky vitamin B cans are now easier to open also.
RV-8A builder
A&P mechanic
Aviation Plasticized Pigmented Polymer Application Engineer
Old 10-18-2007, 09:42 PM
Frank Frank is offline
Great idea. I love it however, this is a gas cap opener. Some of you may recognize another convenient use.
Frank M
RV8 500 Hrs Sold
RV4
300 Hrs Sold
RV3(B) Sold
RV4 Refreshing engine
Old 10-18-2007, 10:46 PM
szicree szicree is offline
Good luck getting on an airliner with those evil looking things
Steve Zicree
Fullerton, Ca. w/beautiful 2.5 year old son
RV-4 99% built and sold
Rag and tube project well under way
paid =VAF= dues through June 2013
Old 10-19-2007, 07:12 AM
jrsites jrsites is offline
Looks like there's an "L" on the opener at top in the picture. I assume you made one for the right side cap as well?
Jeff
Wichita, Kansas
-7 Planning Kit
Old 10-19-2007, 07:35 AM
AlexPeterson's Avatar
This one also has another function - it gets me to the airport (I'll let you guys figure out how it works)
Alex Peterson
RV6A N66AP 1700+ hours
KADC, Wadena, MN
Old 10-19-2007, 07:46 AM
Ironflight's Avatar
Nah...that's a stress riser! I better get out my polisher again.....
Paul F. Dye
Old 10-19-2007, 08:46 AM
MacNab's Avatar
MacNab MacNab is offline
That's not a gas cap opener......now this, this is a gas cap opener. It'll also cut sheet metal and seat belts...hope I don't ever have to use it for that.
Doug
RV-6, AT-301, G-164, C-188...
Old 10-19-2007, 09:43 AM
Rick6a's Avatar
Rick6a Rick6a is offline
Default Time Wasters
Well, what do you do when you find a scrap of 1/8" aluminum and are standing in front of your band saw?!?......
The moral? NEVER throw away scfraps....you'll eventually find something to do with them...Paul
With little more than a bandsaw, small drill bits and pattern files, I've fashioned several aluminum words including AVIATOR, PILOT, N3107X, and the one shown. With steel stock, I've even been known to fabricate Ninja throwing stars as a mindless diversion.
Rick Galati
RV6A N307R"Darla!"
RV-8 N308R "LuLu"
EAA Technical Counselor
Old 10-19-2007, 10:24 AM
MacNab's Avatar
Shuriken (throwing stars) also make great gas cap openers, just be careful about which pocket yer carrying it in.
Doug
