Old 10-17-2007, 03:58 PM
prkaye prkaye is offline
Default rudder cable holes
The 706, 707 and 708 bulkheads consist of left and right halves. On drawing 21, they indicate a hole for the rudder cable on the right half of each bulkhead (note 1) that must be enlarged to 5/8. They don't indicate explicitly whether this is supposed to be mirrored on the left half of these bulkheads. I'm assumgin there will be a left and right rudder cable, and so i should also enlarge the corresponding holes on the left halves of these bulkheads... is this correct?
Phil
RV9A (SB)
Flying since July 2010!
Ottawa, Canada
Old 10-17-2007, 04:16 PM
cjensen's Avatar
cjensen cjensen is offline
Yep!
Chad Jensen
Astronics AES, Vertical Power
RV-7, 5 yr build, flew it 68 hours, sold it, miss it.
