Old 10-16-2007, 10:04 AM
Rick RV-4 Rick RV-4 is offline
Default Whelen vs Aeroflash
About to order my lights - in either case I'm going with the "all in one" NAV/STROBE/POSITION light package, just to keep it simple.
Anyone have any pros or cons about the lighting packages from either of these companies? Looks like the Aeroflash units are about $200 cheaper, so I'm planning on going that route unless I hear some bad stuff about them.
Also, when wiring these lights, I'm planning on using a switch for NAV and POSITION together, and then a separate switch for the STROBES (I know you can use a progressive switch to do this but I'd like to keep them separate). Any thoughts?
Thanks in advance . . .
Rick
Old 10-16-2007, 10:19 AM
alpinelakespilot2000 alpinelakespilot2000 is offline
I think this is a good idea and is how I am wiring mine. I don't think progressive switches make sense here, even though I think I saw something in Aeroelectric Bob's book suggesting this. There are going to be times when you want the nav lights on but no strobes (in clouds, for example), and times when you want strobes but no nav lights (daytime, for example).
Steve M.
Ellensburg WA
RV-9 Flying, 0-320, Catto
Donation reminder: Jan. 2021
Old 10-16-2007, 01:24 PM
frankh's Avatar
frankh frankh is offline
Default On my old Zodiac
I had nothing but trouble with my Aeroflash power supplies...I got real good at replacing capacitors.
So far the strobe package from www.creativeair.com (he buys them from police supply outfit that advertise on the web) has be trouble free.
Frank
Old 10-16-2007, 01:59 PM
Mel's Avatar
Mel Mel is offline
I've been running AeroFlash strobes since the early '80s with no problems. My RV-6 will soon turn 15 years old and the AeroFlash strobes are still going.
The secret of strobes is to keep them working. Strobe power supplies that sit for months tend to have the capacitors go bad.
I have a set of strobes for my bi-plane on the shelf. I plug them in and let them run at least once a month.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 10-16-2007, 02:38 PM
Thanks so far guys . . .
Mel, the gal I talked to at Aeroflash said the same thing. She said they were backlogged about 6 weeks, but encouraged me not to buy until I was just about ready to fly due to the "aging" effect on the components. Guess this is what she was talking about.
Curious to see if anyone has had this problem with the Whelen products.
Old 10-16-2007, 03:39 PM
frankh's Avatar
Default A number of us
Zodiac drivers had the same issue with the Aeroflash Power supplies.
frank
Old 10-17-2007, 08:30 AM
Chino Tom's Avatar
Chino Tom Chino Tom is offline
I've got Whelen individual power packs in the tips of my -6. 9 years and 800+ hours with not one issue. They have always worked when the switch is up!
That being said, I'm going to buy the Aeroflash for my -8 (heh). Hard to justify the price difference.
Tom Prokop
Chino, CA
RV-8A,180/CS/Carb, AFS 4500 EFIS/EMS
RV-6, sold, 820 hrs of fun.
Old 10-17-2007, 11:23 PM
JoeBlank's Avatar
JoeBlank JoeBlank is offline
Default Aeroflash....
400+ hours on my doubleflash units and no problems. Also put a set of them on my old C-170B which operated for several hundred hours with no issues before I sold it. YMMV....
Joe Blank
RV-6
IO-320-D1A
Advanced Flight Systems
Van's Aircraft Inc. Technical Support-Retired
EAA Tech Counselor & Flight Advisor
www.westcoastravens.com
Old 10-18-2007, 06:41 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default flash!!
My AI buddy tells me that the Whelen products see far fewer service issues than the Aeroflash. I personally like the flash pattern of the Whelen Comet power supply, but they take a while to form up the caps if they sit idle for long periods. Good idea to turn them on during preflight runup to keep them in shape.
HTH...Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 10-18-2007, 08:36 AM
DSmith DSmith is offline
Whelen will soon have A650s with LED nav lights available. Will be a different P/N.
Danny
