Old 10-14-2007, 08:35 PM
N941WR's Avatar
N941WR N941WR is offline
Default Wing bolts
I'm not sure where to post this so I'll just dump it here and the moderators can move it, if they wish.
Back in the beginning of July when my wings were installed at the airport I had lots of help from other RV builders and tech inspectors. Everyone looked over the installation and said it all was good, go forth and aviate. Aviate I did.
Today I was helping a friend bolt the wings on his -7A and after installing the four big bolts and four small bolts he asked for two AN4-13A bolts for the wing spars. I commented that my -9 didn't have these two extra bolts. He replied, "Are you sure?" Back in my hanger, I pulled the drawings out and sure enough, the -9 also uses two AN4-13 bolts per side. Off came the seat pans and wouldn't you know it, those bolts were missing.
The installing was a non-event, which tells me the center section has not been deformed in the 60 hours it has flown.
I post this because it makes me wonder how many other -7 & -9's (-8's?) are out there flying without these bolts.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 10-14-2007, 09:00 PM
G-force's Avatar
G-force G-force is offline
Wow, the DAR missed something as important as missing wing bolts?!?!
Mike Sumner
Castaic, Ca
Old 10-14-2007, 09:17 PM
LifeofReiley's Avatar
LifeofReiley LifeofReiley is offline
Default DAR
A DAR cannot review kit plans for every kit plane type and verify every bolt is in place. That's a builders task. I will bet the DAR did make sure the BIG bolts were in place though. Torque specs are also a builder task. The DAR is not going to put a torque wrench on every bolt either. I guess the lesson here is if you have extra bolts in a subkit bag, identify them and review the breakdown sheet until you find where they go.
Reiley
Retired N622DR - Serial #V7A1467
VAF# 671
Repeat Offender / Race 007
Friend of the RV-1
Old 10-15-2007, 12:24 AM
Pilottonny Pilottonny is offline
Question Plate nuts were installed?
Bill,
If you only had to install the bolts, I guess you did have the plate nuts installed on the wing spars during the wing construction?, or did you use lock-nuts instead? (that must be difficult, ones the wings are installed)
Regards, PilotTonny.
"Pilottonny"
Tonny Tromp
Lanaken, Belgium (EU)
RV9A, Registration: PH-VAN
ECI-Titan IOX-320 with dual EI, turning a Whirlwind 200RV CS prop.
Sold
Old 10-15-2007, 07:00 AM
N941WR's Avatar
No DAR, the FAA did my inspection. He just circled the plane and went straight to the paperwork. Still there must have been five RV guys helping and all of us missed these four bolts.
Originally Posted by Pilottonny View Post
Bill,
The plate nuts were installed way back when I worked on the spar, so all I had to do was put the bolts in and torque them.
Bill R.
SC86 - Easley, SC
Old 10-15-2007, 07:58 AM
bsacks05's Avatar
bsacks05 bsacks05 is offline
I installed those bolts together with the other ones. However, I was in the frame of mind that they would need to be tapped in as the other ones did. After tapping for a while and not getting anywhere, I was puzzled. Then I looked closer..........the nutplates you dumba**! You're hitting the nutplates!
Bruce Sacks
RV-9 N659DB - Flying since 7/1/06
Hatz CB-1 - Fabric covering with Polyfiber.
Warner Robins, GA
A&P
APRS KJ4EFS
Old 10-15-2007, 08:05 AM
carguy614's Avatar
carguy614 carguy614 is offline
Default bolts
Hmmmm.. Looking at my 9A and fail to see those bolts you are referring to. Looks like I missed them too. Maybe I am blind, but where are those things supposed to go anyway?? Do they insert from the aft side of the spar box??
Thanks...Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
Sold to nice folks in Texas and badly missed.
RV9 in progress
Old 10-15-2007, 11:28 AM
N941WR's Avatar
Thanks...Chris
Chris,
They are positioned vertically between the top and bottom rows of bolts. When the wings are installed, they are hard to spot but if you feel down there you will find the holes.
Bill R.
SC86 - Easley, SC
Old 10-15-2007, 06:14 PM
robertahegy's Avatar
robertahegy robertahegy is offline
Moderator/Tech Counselor
They are in on the outside edge of the spare box and go in from the rear. These should be checked along with the other wing bolts and the control linkage during the annual condition inspection. Two bolts inserted horizontally in a vertical pattern that engage the nutplates fastened to the wingspar web and doubler. Look on plan 11 for 7s. You need to remove the front seat floor plates to see the bolts. Unless you have a video probe.
Roberta
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
Old 10-15-2007, 06:25 PM
carguy614's Avatar
Default bolts
Thanks Guys!! I missed them totally. Nutplates invisible from the top with gear weldment in place. I'll bet there are a few others out there missing as well!!
Thanks again...Chris
Chris Schmitt
Shallotte, NC
RV9A 90970 N614RV
RV9 in progress
