10-11-2007, 11:06 AM
VAF Moderator / Line Boy
Looking for "Z-Channel"
OK, I did a real superficial search of Van's and ACS web sites, and either missed it, or didn't put enough time into the search....but hey, there are thousands of folks reading the forums, and one of you can probably give me the answer in a lot less time....
I'm looking for some Z-Channel in different sizes (probably with a 2" web dimension would be ideal) for a panel rebuild project - can anybody point me at a catalog source web page?
Thanks!
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
10-11-2007, 11:11 AM
Senior Curmudgeon
Rebuilding a 6, or an 8 panel??
As far as the "Z" channel, probably just as easy to bend up what you need with a brake---------with all the RV activity going on there in Texas, y'all should be able to find one.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
10-11-2007, 11:20 AM
The "Z" channel would be for my -6, but I'm clueless on what a "brake---------" might be.
10-11-2007, 11:27 AM
Senior Curmudgeon
A brake, in sheet metal verbiage, is a device used to make precise bends in sheet metal.
Big wide clamping jaws, and a movable platen you use to fold the metal.
Examples here http://www.nextag.com/sheet-metal-be...ke/search-html
Mike Starkey
VAF 909
Rv-10, N210LM.
Reason: add link
10-11-2007, 11:33 AM
Search for "Tank Attach" on Vans site.
It is the only Z channel that I know of, but maybe they would sell you longer pieces. I used a number of these to mout verious things.
Strobe power supply, BMA EFIS Lite.
Kent
Kent Byerley
RV9A N94KJ - IO320, CS, tipup
AFS 3500, TT AP, FLYING....
Canby, Or
10-11-2007, 11:47 AM
Z-Bracket
Paul,
Airparts in Kansas City has it. I bought a 6' length there recently.
Scott
10-11-2007, 12:10 PM
Thanks, Mike. I'm learning.....
Took the shortcut and just bought my RV.
10-11-2007, 12:53 PM
How about channel's?
Paul,
If you could use a channel with a web of 1-1/2 and legs of 3/4 I can help. Or how about a 2 x 1 angle, you could back to back them for a "Z".
The channel is .125 wall and the angle is .062. Both are 6061-T6.
PM if you would like to try them.
Paul Rose
RV-9A 91300
N417PR
SERFI 2013 Awards
Inspection Complete!!! 7/7/12
First Flight 7/22/12
10-11-2007, 07:11 PM
Gary Bricker
Try Metal Mart. They are a chain so I bet they have a location in Houston.
10-11-2007, 08:11 PM
Van's Z channel
Paul,
Search AZ6 but it looks like only one size is available.
Z CHANNEL X 18"
AZ6-063X1.125X625X18 $4.66
Andy
