Originally Posted by Phil
3) Don't use the deburring tool, just swipe the holes with 3M Maroon pads and remove the jagged burrs.
This was what I did and it seemed to work OK - keep in mind my 7 is not flying yet...
I found that a few passes over each hole followed by a swirl of a maroon pad pressed with my thumb worked really well. The first few holes that I tried to do with my deburring tool seemed to get bigger even when I just did one light revolution on each side.
Somewhere in the red book, Standard Aircraft Handbook I think it is officially called, it says that you don't even need to deburr things that are going to be form-countersunk (dimpled). I always do it anyway though.
Edit: Bottom of page 87, Sixth Edition Standard Aircraft Handbook for Mechanics and Technicians: "Deburring shall not be performed on predrilled holes that are to be subsequently form countersunk."
