w/a Donation
VAF on Twitter:
@VansAirForceNet
Old 11-19-2023, 01:18 PM
thiggins thiggins is offline
Default Trim buttons on Control sticks not working
I'm in the process of attaching the empennage, and wanted to verify everything before final riveting. ( No wings attached )
In my shop, with everything powered up, good voltages...
I cannot get the trim buttons on the sticks to work.
From the Garmin side ( configuration menu ) all is good. I can do full up trim and full down trim via the Garmin menus. ( Strange thing also, the full up and full-down trim voltages seem reversed. I can fix that, but...)
Everything else seems to work great. This is the only issue I have right now with the electrics.
I've downloaded the latest everything, re-loaded everything ( config files, g3X updates...). I can hear the pitch servo click when changing indicated airspeed to true airspeed.
I've also been studying the wiring diagrams and wondering if it's an AV-60000 problem. I even tried disconnecting the pilot side stick, but not the co-pilot side yet.
Ideas?
Thanks in advance
Click image for larger version
Donation 2023 paid
ASEL INST COMM Tail-wheeler
RV-12iS builder (Avionics alive, engine mounted, shop out of order ) Got a hangar, and moved some large pieces in! First start soon.
https://eaabuilderslog.org/?blproject&proj=7buPHH99v
Old 11-19-2023, 02:09 PM
Bob Y Bob Y is offline
Have you tried jumpering voltage directly to the trim servo just to confirm itís working correctly? A 9-V battery is all you need. If you can jumper it at the DB9 connector at the AV-60000 it would confirm your connection at the servo too.
Bob Y - builder 12iS
N569TT first flight 2/9/2020
Greenville, SC
#121047
Old 11-19-2023, 02:13 PM
ďÖ From the Garmin side ( configuration menu ) all is good. I can do full up trim and full down trim via the Garmin menus.ÖĒ
Yes, trim motor works fine, I can test it from the Garmin configuration menu successfully.
Donation 2023 paid
Old 11-19-2023, 02:20 PM
Are your stick grips rated to carry the current required for the trim system? I know some of the Ray Allen grips need to be paired with relays because of that issue.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019? (actually 2022) RV-10 N46BX
Old 11-19-2023, 02:26 PM
Yes, they are provided in the kit, by Vans. This is an E-LSA build.
Donation 2023 paid
Old 11-19-2023, 02:30 PM
StephenC's Avatar
StephenC StephenC is offline
Just check the wires go to the correct pins on the 50 pin connector . We were tracking down a couple of problems and found the wires were in incorrect pin holes on the large connector . Four wires so far and I suspect we will find more with the latest problem we have. The circuit diagrams on the downloads page are available to help. I donít think the checking on the supplied loom is all that good.
Old 11-19-2023, 02:44 PM
wirejock's Avatar
wirejock wirejock is offline
Default Trim
Originally Posted by StephenC View Post
Just check the wires go to the correct pins on the 50 pin connector . We were tracking down a couple of problems and found the wires were in incorrect pin holes on the large connector . Four wires so far and I suspect we will find more with the latest problem we have. The circuit diagrams on the downloads page are available to help. I don’t think the checking on the supplied loom is all that good.
Yep. Start by checking the wires that operate trim. Make a jumper with the correct gender pins and jumper them a pair at a time. If the Garmin runs the trim, it has to be between the sticks and the final D-sub. If none work, my money is on an open ground wire.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
Old 11-19-2023, 02:52 PM
Originally Posted by wirejock View Post
Yep. Start by checking the wires that operate trim. Make a humper with the correct gender pins and jumper them a pair at a time. If the Garmin runs the trim, it has to be between the sticks and the final D-sub. If none work, my money is on an open ground wire.
All the other buttons on both sticks work, so ground there must be good.
Garmin drives the trim motor fine. 50 pin Dsub ? Very confident the 9 pin is good.
Donation 2023 paid
Old 11-19-2023, 03:13 PM
wirejock's Avatar
Default Wiring
Easy to find out. Like I said. Short the correct pairs starting at the connector closest to the system and work outwards.
Larry Larson
Estes Park, CO
Disclaimer
Old 11-19-2023, 04:26 PM
Thanks for the help.
I just checked the pins on everything with "trim" on it:
AV 50 pin and 9 pin, pitch servo, sticks, trim motor itself...
Nothing obvious, no wrong wire colors, nothing fell out.
I will try your plan and bridge the pins (trim up and down) to ground going into the AV-60000
Donation 2023 paid
