Keep VAF
Going
w/a Donation
VAF on Twitter:
@VansAirForceNet
11-16-2023, 06:54 PM
Molding the windshield upper fairing lip
The plans for the sliding canopy show a fiberglass fairing that is molded directly onto the plexi windshield above the roll bar and overlapping the slider edge by 1/4" to 1/2". Obviously the fiberglass needs to bond to the windshield, but NOT to the slider. Normally I use packing tape as a bond breaker, but in this case there is a gap between the windshield and the slider and anything that is put over to bridge the gap while molding will result in the 2 parts being stuck together, forever!
How did you do the molding without gluing the two parts of the canopy together? (other than making a removable fairing and then bonding it on afterwards with Sika etc.)
Thx
Paul.
Paul vS
Building RV-6A #22320 O-320 FP, slow build, 80% done.
Flying my Aeroprakt A-22 STOL and the aero club's RV-9A while I build
11-16-2023, 07:02 PM
Mask your rollbar with packing tape or your release agent of choice.. Tape a piece of thin cardboard across the top of your canopy to bridge the gap between the canopy and rollbar. Use packing tape to mask the cardboard and your canopy. Maybe add a layer of wax or other release agent on top of the canopy.
Do your layup and the cardboard should support the fiberglass while it cures.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019? (actually 2022) RV-10 N46BX
11-16-2023, 07:39 PM
Thanks Kyle. I'm not sure if I understand correctly - if there is packing tape above the rollbar then this would prevent the fiberglass from bonding to the windshield, wouldn't it?
Paul vS
11-16-2023, 07:52 PM
Sorry. Packing tape on the aft face of the rollbar, just in case you get a drip or run of epoxy.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
11-16-2023, 08:02 PM
fyi- I looked at a couple of options to bridge the gap between the canopy and aft fuselage when I was laying up my slider faring, and finally discovered that Michaels craft store sells plastic poster board. It's only about .010" thick and a similar stiffness to a plastic milk jug. Might work for you depending on what sort of curvature you need.
11-16-2023, 08:26 PM
3M Heavy Packing Tape
3M Heavy Packing tape.
Mine is 1" aft of the canopy seam. Also a pocket on either side for the canopy trim to slip in.
Larry Larson
Estes Park, CO
E-mail: wirejock at yahoo dot com
Builder Blog: http://wirejockrv7a.blogspot.com
Donated 12/2022, plus a little extra.
RV-7A #73391, N511RV reserved
Disclaimer
11-16-2023, 09:24 PM
Can you create a filler made of chipboard (represented in green) then use the packing tape (represented in red)...
Thierry Allred
RV-9
Empennage complete
Wings complete
Working on Fuselage
11-16-2023, 10:28 PM
I have seen some folks tend to lift their canopies while sliding them forward & bashing their fiberglass fairings while closing & latching it, don't know, maybe just how they swing their arm forward I guess.
So I prefer a larger gap between the fairing & canopy, accomplished by stacking a few (4 or so) layers of duct tape on the canopy than applying a liberal amount of mould release before laying up roll bar fairing. I also make the fairing thicker/stronger to better resist damage from unknowing passengers who grab it while lifting themselves out of the seat.
Ralph
Now retired - my builder assist shop now closed,
11-18-2023, 12:37 AM
Thanks everyone for the replies, there are some great suggestions that I hadn't considered.
Ah that makes sense. I was hung up on trying to prevent any leaks by putting tape on top but I can mask inside instead!
I can obtain something similar here, Officeworks has free offcuts of the plastic film that is used to laminate posters, it is .007" thick and reasonably rigid.
I also like 3M, it doesn't leave any residue like cheaper tapes. I will extend the lip around the side skirts also.
Originally Posted by Thierry A
Attachment 51260
The gap between the windshield and the slider is uneven but I think that idea will work by using some self-adhesive foam tape that can compress where the gap is a bit tighter.
Thanks, I will do this. I was concerned about water leaking in but it is probably going to leak anyway no matter how closely the lip fits to the slider.
Paul vS
11-18-2023, 11:40 AM
"Thanks, I will do this. I was concerned about water leaking in but it is probably going to leak anyway no matter how closely the lip fits to the slider.
I install a foam weatherstrip on the rollbar to seal the canopy joint, no leaks for the 4 sliders I built. & it actually reduces the noise level in flight too!
Ralph
Thread Tools |
Search this Thread |
Display Modes |
Linear Mode
