Originally Posted by craigvince
The builder's manual that came with my kit said to use EZ Turn on all AN fittings, so that's what I did.
If you want to use it for anti seizing properties, then that's fine. Just keep it off the 37 degree cone shaped metal surfaces that make the final seal.
In the refrigeration/AC business, I've often used refrigeration oil for small copper tubing such as you'd use for primer lines, by putting a small amount of oil around the tube where it goes into the flare fitting hole. This is to prevent the flare fitting from trying to twist and stretch the flare while its making it's tight metal to metal contact. This oil is just on top of the flare, and not in the mating surfaces.
Personally, for the larger flared AN fuel lines, I didn't use any anti-seize lubricants.
L.Adamson
