Soldered pins
The pins are soldered and Klaus really doesn't like it when you remove the pins (discussed in other threads).
I just finished cutting the hole for mine. I cut a slot approx 1 1/4 x 9/16 which is big enough for the d-sub with the shell removed. The slot is small enough I can cover it using a 2-piece SS firewall shield.
I cut a hole in a piece of scrap to make sure I had the size right before cutting the firewall. I then used the scrap as both a template and a doubler.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
